Question about RCA HD52W59 HDTV Projection Television
Tv dont turn on beeps 3 times when i push the on button need help
  • 668 Answers
Chances are you have a High Voltage Transformer failure. To be sure though a professional should check it out.
Posted on Jul 18, 2009
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
I have a ps3 60g but i dont have no hd cord for it so am using it on a normal tv. but i cant see no video but am hearing audio on it, could someone please help me!!!!
Ok you need to reset the definition back to standard. Follow these steps :-
1. Turn the PS3 off into standby (red light on)
2. Press and hold the power button. It will beep once when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
3. Wait for the display to initialize.
Hope this helps
Oct 31, 2010 | Sony Playstation 3 (PS3) Console
Can't seem to connect Playstation 3 to Toshiba 30HF84. No picture comes up on the HDMI screen of the tv. It's not the cable cause that worked fine on another tv.
ok kepp push on the power button on the ps3 its gonna beep ones then its gonna turn off than turn on again but keep pushing on the button its gonna beep ones then its gonna beep twice remove your fingur when it beep twice but make sure the hdmi connected its gonna ask you on the screen you want it to work with hdmi you gonna enter yes
Oct 17, 2010 | Toshiba 30HF84 30" TV
How do I change my device output to HDMI when i cant see the screen on my tv? I dont have the other rca adapter and I am switching to another tv
Push and hold the power button on the front of the PS3 until it beeps a 2nd time, then let it go. The video reset screen will appear, just answer the questions "Yes" and you'll be good to go. Oh, you may need to plug in your controller with a USB cable to do this.
May 24, 2010 | Sony Playstation 3 (PS3) Console
Turn's on but i don't get any feed back on tv. tried using 5 plug rca and 3 plug rca tv doesn't have hdmi input
Was it Hooked up to HDMI before you tried those cables? You can reset the video settings of the PS3 by holding your finger on the on switch when you turn it on. Leave it on there till you hear it beep a couple times then shut down. Hope this helps. Good Luck
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on nuthin would show up on the tv. You can't even hear anything on the tv...it's just blank. Someone please help me..!!!!!!!!
Alright mate, Try these steps...
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play discs
to me it sounds like your lens are messed up, try getting a dvd cleaner and use it on your ps3 man
Apr 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
RCA HD52W59 HDTV Projection Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
