Question about Canon ZR60 Mini DV Digital Camcorder
Well i don't have a fire wire connection
Dont have a firewire port on pc so how do i upload video from my sony zr there a adapter to go from the firewire port on camcorder to usb port?
    Brigadier General:
  • 6,966 Answers
To my knowledge there is no simple adapter that would interface Firewire to USB. Though both are high-speed bus, there is significant difference between the technologies involved that they can't be joined/integrated nor is it possible to connect a USB device to a Firewire port either directly or vice-versa. Most if not all on the market are a dual/combination Firewire/USB hub but not an adapter.
1. If your computer is a desktop, there are PCI cards that plugs in to one of your PCI slots whose inputs are Firewire based. Here is an example; or
2. If your computer is a laptop, there are PCMCIA cards with Firewire ports. Here is an example .
Pls be reminded that there are 4-pin & 6-pin FireWire DV Cable.
Hope this be of some help/idea. Pls post back how things turned out or should you be in need of additional information.
Good luck and kind regards.
Posted on Nov 19, 2007
My sony PD177 firewire por is Not working, it can't connecting to my PC
The problem with pd 177 its that it can burn the fire wire port and its not able to communicate with the pc you should check that the fire wire ports to see if they are working if they are then its the fire wire port that needs to be replaced.
Check the ebay you might be able to find one there.
hope that helps as my selfe had the same problem .
Feb 12, 2014 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sir when I canect my dv camcorder pc via fire wire ...but not capture video..and erorr show code 1021 ...there are no free reusorses in to solve me....thanks..
see this topic and contact the supplier .God bless you
FireWire connection to computer keeps getting dropped. Check with manufacturer to make sure you have the latest driver and firmware updates for your camera and computer. Always turn the camera's power on before making a FireWire connection. Disconnect the FireWire cable before turning the camera off. Use the camera's AC adapter when making FireWire connections. Try a different FireWire cable and try connecting the camera to a different computer. FireWire cables and ports sometimes fail.
Nov 07, 2013 | Video Cameras
How do i make a ieee port on the computer to connect via ilink cable
Well you need to buy the Fire Wire Card from PC World, the card pushes into the side slot and then at the back of your PC you will see the Fire Wire port you now have, you will need a standard Firewire cable and then your all set.
Apr 11, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Aug 21, 2009 | Canon ZR500 Mini DV Digital Camcorder
Fire wire to PC Express so known as ieee 1394 ..or fire wire ...or might though prompt you for a driver ...
Jul 18, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Can't upload videos to computer
Hi, I am not sure why cameras dont come w/ firewire cord. May be its expensive..?
Neways, You need to use the 4 pin firewire to 4 pin firewire cable to connect PC to the camcorder.
This camcorder model has the firewire port. Please check the manual carefully to find its location.
You need to switch on the camera. Keep it in play/ edit mode. Open movie maker. Its should detect the camera now. If not, try installing the software which came with the camcorder. It might have any drivers.
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Sony Handycam DCR-HC28
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg.
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to there are some guides on their website as well (eg.
I hope that helps.
Aug 12, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Video Upload
Only digital signal can be uploaded on PC but your camera is analog model and you can't connect it directly with PC. You need to install MPEG card in PC to digitize the picture signal of camera to upload in PC.
Jun 08, 2008 | Sony CCD-TRV238E Camcorder
Canon ZR60 Mini DV Digital Camcorder Logo
204 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
