Question about Xerox Phaser 8400 Laser Printer
Totally dead - power cord is fine is there an internal fuse
    New Friend:
  • 180 Answers
No it dont have a fuse u will need a new power supply for it
Posted on Jul 18, 2009
No power
yes there is an internal fuse connected to the cord inside of the cover.normally at the connection of the cord.
Nov 08, 2013 | General Electric PVM1870SMSS Microwave...
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
TV Totally Dead
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
CH-DVD 320-won't come on at all. Used to work fine. Now won't come on, it's dead.
If your unit has no led light lit on the front panel, this is an indication that the power supply board is not working(dead).
First thing to check is the basic, I'm assuming that your outlet is live. Check the continuity of the power cord using the multimeter. Sometimes it has an internal broken wire due to frequent pulling and bending. If the power cord is good, open the top cover of the unit and check the internal fuse. Sometimes due to voltage surge and aging, fuse fail. If this is the case, replacing with same current(ampere) ratings will cure the problem.
Let me know if the fuse is intact or blow again after the replacement to determine the next steps.
Jdvillanueva
Jul 11, 2011 | Televison & Video
I have a bosch pb360 boombox that wont turn on with new batteries and the fuse is fine
There are two internal glass fuses inside the Bosch pb360sc.
If it won't power on, flip it upside down and remove the bottom section of the radio and four of the screws for the roll cage. Once inside you can figure out which fuse is dead and replace it. The Bosch manual is totally useless and does not tell you or indicate that there are any internal fuses. The fuse that runs the 12volt power supply / cigarette style outlet has nothing to do with your radio not being able to turn on/ power up. I guess they want their service partners to be able to jam you for .50 cent fuse....
Apr 07, 2011 | Bosch Audio Players & Recorders
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Jan 23, 2010 | KitchenAid KHHS179LSS Convection /...
Sharp R1420B Totally dead. Power to unit is ok.
Most of these have internal line fuses inside of the casing. Once you remove the housing that covers the top and sides, follow the wires from the cord and they should lead you to the fuse. They are usually on the front rh side looking at it from the front. Be careful, even though unplugged, this unit still stores alot of electriacal energy in the capacitor.
Oct 26, 2008 | Microwave Ovens
Jensen CD-1500D
you'll be lucky if the power cord is at fault, try another cord. for component checking, try if u can find the main fuse if blown, try replacing it. totally dead gadget sometimes only points to a faulty power supply.
May 17, 2007 | Jensen CD1500D Cassette/CD Boombox
Xerox Phaser 8400 Laser Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
