Question about Solo 471 Silent Gas Blower 52 Cc
SOLO 471 WILL NOT START. IT WAS RUNNING AND JUST QUITE
3 Suggested Answers
  • 1116 Answers
SOURCE: What are the initial high
Hi, my name is Todd and I am going to try to help you with your problem. Ciould you please try the following prior to jet settings on this unit:
Carburetor adjustment may be needed on some 471 units.
Affected units will exhibit low RPM, sluggish performance and poor throttle response.
It is best to use a tachometer when adjusting to ensure accuracy. Set The unit to operate
at a high speed RPM of 4,800 and an idle speed of 2,500 with all blower tubes installed. To make
the adjustment follow these steps.
1. Remove the four torx screws located in the corners of the blower housing by turning them counter clockwise.
2. The high speed adjustment is located on the left. Both screws have red caps installed that limit the amount of adjustment. A jewelers screwdriver is needed to make this adjustment. If not
available, the caps must be removed. To remove the caps pry slightly upward on the black body
around them. This will loosen caps for removal.
3. Adjust by turning the high speed screw clockwise until it stops. Do not overtighten! Turning
1 1/8 turns counter clockwise will provide an approximate setting. Use your tachometer to adjust
precisely. Replace limiter caps and black body.
After you have done this let me know if you are still experiencing issues and what the issues are at this point and we can move from there. I am here to help.
Posted on Jun 25, 2011
plink_plonk
  • 1807 Answers
SOURCE: solo 471 blower lost power
I will try and help with your question. Could you please tell me if the throttle on your carb is fully activated when your trigger is squeezed. Or is there still more travel on the carb? I'm looking at each possible fault individually, In this case, many back pack blower have adjustable throttles to take any slack out of the throttle cable, and yours may have slipped. But I am unfamiliar with your machine so require a little more information.
Posted on May 01, 2016
Solo 471 blower lost power
May 01, 2016 | Solo 471 KAT Backpack Blower - SL 471
My passport only has 698 gigs when the box said 750 gigs what do I do?
Live with it :)
This is a never-ending story of billions of bytes versus gigabytes:
One 'proper' gigabyte is 1024x1024x1024 bytes = 1 073 741 824 bytes
Therefore 698GB = 1073741824 x 698 = 749 471 793 152 bytes = ~749.5 billions of bytes, which is advertised by manufacturers as 750GB, quite incorrectly, but better sounding from the marketing vievpoint :)
Jul 22, 2011 | Computers & Internet
Solo 471KAT will not start hot....runs fine when started cold
Check your (gas) mix, it sounds 'hot' >>> not enough oil. Mix is the easiest thing to mess up and causes the most problems.
Feb 22, 2011 | Solo 471 Silent Gas Blower 52 Cc
Starts fine, idles fine, when I rev it up to full throttle it runs at full RPMS for 8-10seconds, then looses RPMs gradually then revs back up gradually! Also, this is a Sears Professional 360.796900, but...
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Nov 25, 2009 | Solo 471 Silent Gas Blower 52 Cc
Where can I purchase a silent gas leaf blower
Go to www.solousa.com, there you can find a dealer in your area.
Good day.
Oct 20, 2009 | Solo 471 Silent Gas Blower 52 Cc
Backfired and stopped running. now won't start
did you try a new spark plug? might have flooded from the carb being too rich, or running with the Choke ON.
Oct 14, 2009 | 2001 Ural Solo
Solo 471 Silent Gas Blower 52 Cc Logo
115 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Steve
Steve
Level 1 Expert
Are you a Solo Garden Expert? Answer questions, earn points and help others
