Question about Dopod 818 Pro Smartphone
No connection to Wlan. Can´t understand any protocol. Config with wep, wpa, but can never connect to wlan. Tested in Dlink and linksys eq.
    New Friend:
  • 180 Answers
You need to update phone with cable to your computer should be a real easy fix.
Posted on Jul 18, 2009
I cant access wlan connection using dlink router,im using nokia c3-00 .it always says wlan connection failed even if theres a strong signal
if the router is password protected, try reseting it to open and attempt to connect again. If it connects without security then there is a security log error between the two devices.( which is common for n-type routers and/or mobile operating systems.) you will need to select a security type that is listed within your phones settings.
May 13, 2011 | Cell Phones
I am using nokia e63 phone. When i try to connect to a wlan network it asks for preshared key or wep/wpa key . What should i do?
This is the same key that you use to connect your laptop to wlan.
if it is an office network, you will need to ask the network administrator or someone using the wlan for the key.
Mar 11, 2011 | Computers & Internet
Wont allow me to connect 2 additional computers and need pin name or number
Two methods to solve your problem:
Method 1:
(1) Using your currently connected and working computers, access the wireless router security page at 192.168.1.1 (page 8 of 44 from the WRT54G2 manual), default password "admin" (page 7 of 44 from the WRT54G2 manual)
PDF file of the Linksys/Cisco Wireless-G Broadband Router User Guide:
http://belkashop.com.ua/products_files/WRT54G2_V10_EN.pdf
You'll need Adobe Acrobat Reader to view/print this file - free from www.adobe.com
(2) get the WEP or WPA password, and enter it into the wireless LAN (WLAN) settings on your 2 additional computers.
Method 2:
Alternatively, access the WEP or WPA key on one of your working PC, by
(1) make sure the printer is working, powered up and online.
(2) invoke "Network Setup Wizard"
(3) wind thru various steps (click-ing NEXT), then select "Print Network Settings"
(4) use the printed WEP or WPA key in the WLAN settings on your additional 2 PCs.
Jan 02, 2011 | Linksys WRT54G2 Wireless Router
Wiress LAN not connecting with Gigaset SE587 WLAN dsl
The problem may lie in one of the following: 1.) Input the right password. For example, if the Wlan router is using WEP or WPA, input the right password in the connecting device. 2.) Be sure that the WLAN router and the connecting device to use the same frequency, whether it is using 802.11a/b/g/n. 3.) Check the Router if it is supplying IP address and if it is sufficient.
May 02, 2009 | i-mate JasJam Smartphone
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Router problems
Check with this tip.
Check if router is working on Net using a Lan cable to connect your PCs and check if you can browse from PC..
If Internet OK check if radio is enabled in your Belkin router.
Then check if your SSID broadcast is enabled in your router.
Check if Router and PCI Wlan adapter are on same WLAN standard A,B, G, or N and disable every security protocol (WEP or WPA)
Define a new SSID name and check if you see your Wlan on PC.
Restore your security as soon as connection established.
Jan 05, 2009 | Intel PRO/Wireless 5000 LAN Access Point...
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Connecting to woreless internet connection
Be sure you use same security protocol on your PC than in your WLAN:
WEP or WPA or WPA2 protocol
Passphrase (PSK ) or Password
TKIP or AES.
Use same Key.Passphrase on your notebook as in your Access point.
Check if your Access point/router has access list enabled: either you disable it in your AP either you add your PC MAC address to the list.
Dec 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Got full bar wireless signal...........
Connet to your router using a LAN cable.
Be sure you can browse
Configure your Wlan with same protocol WPA/WEP) and Keys (TKIP)
or remove every protection from your Wlan (not recommanded)
Do you see your SSID in your PC?
Dec 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Dopod 818 Pro Smartphone Logo
80 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
castletech
castletech
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
