1004 tempstar a/c air quits blowing into house
Turn unit on and the unit works for awhile and then continues to run but no air comes thru the vents, unit still running and fan outside on top runs. help
Recently bought the same unit, new but was in storage for several years. Looking for the original list price for the unit itself, so I dont take any losses financially. If and when I do find out, Ill be willing to sell any parts you need to fix your system.
Posted on Dec 28, 2009
  • 614 Answers
Possible fan motor problem. Bad capacitor or bad fan motro. Either way you ned to call a service tech. Russ
Posted on Jul 19, 2009
Hi. I need help fixing my urka-a042jk10e Air Conditioner please. It's not blowing any air up thru the vents and my house is 97 degrees!
Possible that the compressor is not running. Call a service tech. Could be a run capacitor bad, stuck reverse valve or even a shot compressor.
Jul 30, 2016 | Heating & Cooling
Unit freezies ,blow does not blow sometimes
Your unit was run without filters in place and the coil has a dirt/fuzz coating that gets wet from condensation and then freezes when unit is on. When this happens less and less cold air comes out of vents making unit run continuously . The fix. Turn the AC off and run fan only until air flow returns to normal and air is warm. Then carefully remove debris from return air coil on the air filter side
Oct 22, 2015 | Heating & Cooling
CAN'T PULL OUT THE FUSE ON MY TEMPSTAR 10 C/A UNIT
Hello, if tne outdoor unit is running ( fan and compressor) and the indoor blower motor is running and yet the unit does not cool, then a airflow problem or low refrigerant charge are the problems. Begin by checking the air filter to make sure it is clean and check the blower wheel tommakebsure it is clean and running at proper speed. If the unit is clean then looks like you have a low refrigerant charge due to a leak.
Jul 06, 2011 | Heating & Cooling
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Master cool
Make sure you have enough exhaust openings in the house. Turn on the unit with an outside door open and see if the result is the same. To me it sounds as if you have too much back pressure and not enough ventilation.
Aug 29, 2008 | Mastercool 67680 Evaporative Cooler Air...
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
