Question about Hayward SAND FILTER, PRO SERIES
Pushing sand into the pool - Hayward SAND FILTER, PRO SERIES
    President:
  • Hayward Master
  • 1,378 Answers
Replace the lateral assembly and fill the tank just under half way with water before putting the sand back in. For a quote on the part contact us at www.arrowpools.net with your filter model number.
Posted on Jul 18, 2009
Sand fliter handle almost impossible to turn, after pushing down to release the handle
you will have to disassemble, either full of sand due to broken laterals or the pins broken holding the director onto the face plate,
Mar 11, 2016 | Pool & Spa
Our pool is about 90000 litres of water so how big filter do we need please
If you have a above ground pool go with the Cartridge or sand, and if underground go sand or D.E. All have their ups and down you should find out what you want from them specifically cause they all do varying amounts of the same thing.
Sand Filters
(Filters using literally sand)
For sand filters, on inground pools, I like to use a 30 inch tank diameter, which is a 4.9 sq. ft. filter surface area, and holds 600 lbs of sand. For small pools (under 20,000 gals), I might advise the next size down (24 inch tank), if the budget is tight. But never go smaller than a this for an inground pool.
Cartridge Filters (like a air filter)
I have a rule of thumb for cartridge pool filters. 100 sq. ft. of filter surface area per 10,000 gals of pool water, as a minimum. I like to see the 400 sq. ft. models on inground pools above 25,000 gals. These can go an entire season without cleaning in most cases.
D.E. Filters (Ground up fossilized algae)
Because they offer the most superior type of filtration, people tend to go small with DE, and buy a 24 or 36 sq. ft. DE filter. Ugh - go Big! Nothing below a 48 sq. ft. filter, and if your pool is over 25,000 gals, go with the Big Boy - the 60 sq. ft. filter.
Swimming Pool Blog
Also make sure the filter can take the amount of water that the pump is pushing through it.
Jul 23, 2015 | Pool & Spa
Can the filter blow sand into the pool?
If you are using a sand filter and if the plumbing is incorrect you can flush sand into the pool instead of flushing dirt down the drain. If you are using a sand filter and the sand support screen material is torn you can get sand into the pool.
Dec 05, 2014 | Pool & Spa
How tovput water in sand fitler
once the standpipe and sand are in the filter, put the dial valve on. when the pump activates, it will put the water in for you. i recommend starting the system on backwash if you have new sand. that way, any dust will wash out in the first few seconds instead of pushing it into your pool
Jun 12, 2014 | Hayward SAND FILTER, PRO SERIES
Water not pushing out hard
it may need fresh sand in the filter or back flushing? it could also be the pump motor getting claped out
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter not filtering small particles
You probably have too big of pump. It is pushing the finer stuff right back into pool. Try adding a clarifier. Don't backwash either until the pressure goes up.
Jul 30, 2009 | Hayward Pro Series 18" Above Ground Pool...
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
194 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
