Question about Konica Minolta DiMAGE Z1 Digital Camera
Mirror movement When you look through the screen on the back of the camera you see a "mirror" (?) move up & down. Is it fixable? Thank you! I appreciate any help that any one can give me!
The stuff inside the LCD monitor stucked up, is there any remedy regarding this? Thank u
Posted on Mar 18, 2009
How do I fix the electric rear view mirror
Most are not fixable...listen to hear if you hear any movement in the mirror you are working on...if you hear movement but it is not moving then the assembly needs replaced... if you dont have movement check to see if cycling the switch to opposite mirror engages opposite side....if the other moves the one you are working on doesn't then it is the moter in the mirror or a bad switch
Feb 20, 2016 | 1997 Dodge Ram 1500 Club Cab
Can we repair/replace the lcd of old film cameras? I have an old pentax sfx camera and its lcd does not work.
I just checked my SF-1, and the mirror will go through four cycles while trying to load the film. You should be able to hear the mirror go up and down when you open the back and close it, then turn the camera on. I cannot get my SF-1 to keep the mirror up. Check to see if you have the mode set to bulb, and that the shutter release isn't stuck down - that will keep the mirror up until you release the shutter button or turn the camera off.
Also look carefully inside the lens mount on the side nearest the red dot. at the horizontal spot there is an internal button. It should be at the bottom of the track it runs in, about 1/3 of the way from the screw below the red dot to the lens release button. That moves up when the mirror goes up, and down when it comes down. If it is in the up position, you could perhaps try to gently move it downwards. It definitely moves up and down with the mirror on my SF-1.
Jul 22, 2012 | Pentax Sfx Auto Focus Slr 35mm Film Camera...
SLR MIRROR NOT MOVING MUCH
mirror box mechanism ,where a lever which moves mirror,may be broken
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Can't see through viewfinder (it's all black) and cannot trip shutter or advance film. batteries are new and intact.
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Oct 10, 2009 | Nikon FG 35mm SLR Camera
Black photos, stuck mirror
Release the lens, take raw photos and check mirror movement using auto and manual method.
Sep 11, 2009 | Nikon D100 Digital Camera
Bottom 3/4 of photos are black
Check out this website http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
I had the same problem. You can check to make for sure by removing your lens, and carefully lifting your mirror. Does the sub mirror underneath flatten against the other one when you lift it? That's probably what is in the way creating your 3/4 "black" picture. I just repaired mine as in this website, and the mirror moves great now! Of course, I'm used to taking apart laptops and such. If you have a warranty yet, contact Canon. It is a defective issue on there part.
Mar 12, 2009 | Canon Digital Rebel / EOS-300D Digital...
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Film Advance Will Not move
Hi,powerpe. The mirror release rod can be located in the bottom of the body once the plate has been removed.(there are three screws on the old k1000's) There is a gear train on the left side when viewed turned over.The mirror cockong rod is towards the rear and a little right of the main shaft.You might need to move a little silver pawl with a pin or micro driver then you can push the mirror **** in to release the reflex mirror.the mirror cocking rod is about 1/8" dia.Hope this helps
Oct 21, 2007 | Pentax K1000 35mm SLR Camera
Konica Minolta DiMAGE Z1 Digital Camera Logo
209 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
