Question about Astral Products Difusser 1/2 Hp - 1 1/2 Hp
I have a 1/2 hp power astal pool pump, and I need to remove the impeller motor from the backplate, how do I do this
  • kimkimsolo Jul 18, 2009
    thanks, we thought so but, we have to get a bigger screw driver, so we wont strip the screw, because it is very tight
  • 3,037 Answers
The first step is to remove the eight bolts/screws holding the wet end to the motor.After that the pump just slides apart.Once opened the diffuser and seal plate are exposed.The diffuser just slides off the seal plate.To remove the impeller you will need to hold the shaft from the back side of the motor. This one uses a large screwdriver in the slot on the motor shaft. Some use a 9/16" wrench. While holding the shaft unscrew the the impeller.The impeller holds the seal plate to the motor, so it too will come off once the impeller is removed. Let me know how this turns out.
Benjamin
Posted on Jul 18, 2009
How do I fix the seal?
please follow this steps . God bless you
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Nov 23, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
How do I take it apart
follow this steps and fix it. God bless you
Hurlicon pump is throwing out sand from the water jets back into my pool as I am cleaning. Have tried to clean filter and back washed so many times but its not working.
make this steps and fix it. God bless you
Replace a pump seal:
Nov 13, 2013 | Pool & Spa
Rear seal sa200
please make this steps and fix it. God bless you
Nov 12, 2013 | Pool & Spa
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
How do you release the motor from the pump
Take off the impeller. You will need to hold the motor shaft from the back and spin the impeller off. Check in the mouth of the impeller for a screw. This will need to be removed first.
Aug 01, 2009 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Astral Products Difusser 1/2 Hp - 1 1/2 Hp Logo
35 people viewed this question
Top Astral Products Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Astral Products Pool and Spa Expert? Answer questions, earn points and help others
