Question about Hayward 250k Propane IID Low NOx Universal H-Series Heater
Code AO is on display. Went throught the
Code AO is on display. Went throught the steps----vacumn switch is ok, blower motor runs, but not ignition. Book says it has to be one of the two items above. What else could it be. I replaced the elctronic board.... no change
  • 139 Answers
If blower comes on it is calling for heat. i would look at ignitor.it could also be vacuum switch(tube goes to it from blower)however they rarely fail.let me know
Posted on Jul 21, 2009
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
Aug 10, 2014 | Hayward Pool & Spa
1983 Chevrolet C10 Silverado: The AC compressor and heater blower motor fan will not come on.
The brown wire at the speed switch is the power wire. Powers is then directed to the blower motor resistor throught the orange, lt blue and yellows wires. The blower motor receives power through the orange wire. Check for power at the fuse with the key on. If there is no power the problem could be the ignition switch or the wiring in between the switch and the fuse block
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 05, 2013 | Cars & Trucks
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Spa heater will not ignite. Shows "AO" code.
You need to check and see if you have enough gas supply to run the heater. Older heaters would run on a small gas supply but forced draft are hinkey about how much gas they get. Sometimes this is a gas line size problem but more often than not it will be a gas meter problem. On the face plate of your meter their is a number that tells the size. With a 250 and other appliences in the house you will want a 350 or bigger. The good news is the gas company will upsize this for nothing. If they are supplying more gas your buying more gas. It could be other things but this is the first thing to look into.
May 17, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Error AO ON MY HAYWORD H SERIES POOL HEATER
The AO mindicates an open prover switch ,, here from Hawward site .
immediate after error is corrected.
May 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
AO error code
I would have to agree with you concerning the control module.
Jul 31, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward 250k Propane IID Low NOx Universal H-Series Heater Logo
381 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
