Question about Kitchen Ranges
Frigidaire gas range ES100 oven will not light -- burners work fine.
  • 341 Answers
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
Can a ES100 Frigidaire gas range oven be lighted manually when there is no electric
Yes, the majority gas ovens with mains ignition can be bye passed you ether have a grill cover at the top of oven door or the bottom on the outside and somewhere between the grill slots there should be a small shaft with a slot in the end to enable you to turn it by screwdriver to put the gas through to the burner so your can manually when there is a power cut Ect.
Good luck
Mar 03, 2015 | Cars & Trucks
I have a Frgidaire es100 gas range(04-05). The broiler does not fire up and the oven cannot reach higher heats. The burner shows blue flames of about 1" along the length of the burner. The igniter...
Good Morning Robin C Reamer, thanks for your post!
From what you have described the broiler on your Frigidaire range is not starting. In order to have the proper component replaced I would suggest consulting with a professional technician in your area. Based off the information you provided it could be an issue with the burner or safety valve and having a professional come out would reduce the costs of parts. I hope this information is helpful. -Matt
Dec 02, 2014 | Frigidaire Kitchen Ranges
Es100
You will need to replace the "oven control Board". Here is that part to order.
May 20, 2013 | Frigidaire FEF336BC Electric Kitchen Range
The oven will not light and is throwing a breaker. Is this something fixable? It has been slow to light for a while now, and we usually have to turn on one of the stovetop burners in order to get the oven...
can you access the ignition module,if so try using one of the connections from the module that ignites a stove top burner and see if this line connected to the oven lights the oven now and doesn't throw the breaker,then you would know that section of the module is defective
Feb 11, 2010 | Ovens
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Hello, I have a Frigidaire freestanding crown series gas range that has two problems. The most important being that the oven does not light. The stovetop lights, except one burner that you hav to light...
I figured it was the ignitor given the burners work fine and I could smell gas from the oven when I would try to turn it on. So I found a local parts store and bought the replacement ignitor. I cut the wires of the old ignitor close to the ceramic and spliced the new one on with porcelain nuts and voila my oven now works again!
Nov 18, 2008 | Frigidaire Kitchen Ranges
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
1,199 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
