Question about Dryers
Dryer fires but shuts down after 3 - 5 mins - Dryers
  • 864 Answers
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Posted on Jul 18, 2009
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Managemylife com sears
Ohms out the two gas solenoids. You might find one open. Replace both.
Make sure the vent/air flow is not restricted.
Oct 18, 2013 | Kenmore Dryers
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
My GE dryer shuts down after running for a wile when I open the door to check if the clothes are dry. It seems to start back up after cooling down for about 20 min. Any answers ?
There is an overheat protection thermostat that could be faulty, but it usually indicates that the exhaust tubing is full of lint and there is inadequate airflow. This can be a fire hazard, so you should regularly "Shop Vac" the lint out of the pipe.
Dec 16, 2012 | GE Dryers
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
Dryer runs for about 3 min. then shuts off. Its not the reset. Let it sit for a few min. and the power comes back. Stop is flashing on panel.
have you cleaned the filter, so dryers stop if the dryer filter needs to be cleaned, also when you pull it out, clean underneath the filter, down in the dryer, lint gets down in there after a while......it may help.....good luck.....
Jan 05, 2010 | Dryers
Dryer not heating, just worked but 10 mins later isnt hot
most likely a bad thermostat shutting you down refer it to a qualified repairman as these are temperature critical and if you put in the wrong pair it can start a fire
Sep 28, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Hi have a7yr old dryer vent is clean dryer run 10 mins and fire stops and dryer runs
you probably have a clogged vent pipe.
This causes the unit to overheat and shuts down the burners.
Clear all lint from the pipe, the dryer exit inot the pipe, and the pipe exit from the house.
Jan 13, 2009 | Dryers
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
