Question about Sony BRAVIA KDL52XBR2 Television
Remote control doesn't work ar all
Since some months the remote control has a strange behaviour. Since 5 months (7 months after purchase) it started with no connecting with the TV from time to time. Then, since 2 days it doesn't work at al, even after changing batteries.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Get an all in one remote and see if that works they r very cheap to buy
Posted on Jul 18, 2009
Remote doesn't work with reciever
1)Reset the code
2)tight the spring very well with pliers for better contacts
3) resolder the wires contacts batteries
4) Open the remote control for clean the keypads, from oxide, dust,with special spray contacts cleaner.
5) Proof.
God bless you
Jun 21, 2012 | DISH Network IR Remote Control
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I don't have the user instructions for my Philips remote. Need to set up my TV - purchased the remote in 2010, it doesn't show a model/name on it anywhere. How do I find the instructions or apply...
If the TV is a Panasonic, I'm sure the Phillips remote wont work unless it is a "universal" remote. You will need to code it in to work on your TV if its a universal one. See if it has an auto scan button on the remote.
Dec 27, 2017 | Philips SRU3004 Remote Control
It runs 5 to 10 minutes, then it stops. When I press the remote control boton, it works again for 5 to 10 minutes and then it stops. So I need to repress the remote control again to make it starts.
I guess you are having a problem. That model dehumidifier doesn't have a remote control. As a matter of fact, I'm not aware of any model dehumidifier that has a remote control. A remote would be useless. Now, some portable air conditioners have remote controls. Is that what you have? A portable A/C unit? Please advise. Thanks.
May 26, 2011 | Danby DDR2509EE Dehumidifier
Panasonic DMR-EX88 recorder was working fine but remote has stopped working so cant get to the hard drive (can still play a disk by pressing play on the unit). Remote started working intermittently, now...
Either the remote itself is exhibiting strange behaviour, or the unit's IRD controller circuit (and/or the IRD itself) is faulty. Perhaps when you changed the batteries, the remote needs to be 're-commanded' (that means entering a remote code by pressing and holding 2 buttons together for 10 seconds - example - 1 + ENTER/OK) - this should be done whenever the batteries are replaced. If this does not restore the remote to full control, then the IRD (and/or its controller circuit) is the most likely suspect; or, worst case scenario; your remote is defective. I hope it isn't the latter.
I suggest you submit the unit to an authorised service centre for a quote (since this is not a disc drive replacement/alignment it shouldn't be too expensive) then you can decide for yourself afterwards as to what further action to take. Up to you, it is not unfixable. You can always ask Panasonic directly for straight answers and get a second opinion at the same time.
I hope you do not need a new remote at this stage.
Apr 01, 2011 | Panasonic DMRES20D DVD Recorder
Don't know how it works.
manual for the system can be found at scytek.net
Apr 30, 2009 | Scytek 2000RS Remote Control
I have a Hampton Bay or Hunter?? Ceiling fan that is Remote Control. It all of the sudden started acting strange--ie. The light started going from Dim to Bright and none of the functions on the remote...
The canopy should turn either left or right to remove. I'm sure you've tried this, but if the fan's been there awhile, it may just be a little stuck and you need to work at it.
Nov 26, 2008 | Dryers
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Not able to program remote
download manual from:-
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcu807&kw=rcu807&st=&ar=&dt=&so=&pg=1&file=others/rca/rcu807-manual.zip
Oct 12, 2007 | RCA RCU807 LCD Remote Control
Sony BRAVIA KDL52XBR2 Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
