Question about LG Vu CU920 Cellular Phone
It wpnt charge unless i put the charge a certain way
    President:
  • 625 Answers
The first step is to contact your carrier to see if it is covered under warranty. If it is, great, get it replaced.
If not, you have 3 options:
1. You can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. You can get a new phone. Cost 150-250 dollars.
3. You can get an external battery to charger the battery separatefrom phone. The cost is about 25 dollars.
Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VU Charger Problems Fix
Posted on Jul 24, 2009
    New Friend:
  • 180 Answers
Yes i have had same problen i took phone to store and they put a new charge port in it
Posted on Jul 18, 2009
Mower runs new battery down then wont start again unless jumped.
Sounds like you have a problem with a regulator. Hard to tell without knowing what model of mower you own. You must remember that whatever is attached to your battery charges it while the motor is running. If the battery does not receive that needed charge, running the motor will certainly drain your battery.
Apr 17, 2013 | Garden
Battery will not charge
Rechargeable batteries (usually Ni-Cd) have a finite life and after a certain number of recharge cycles (usually 500 times under optimum conditions) will loose their capacity to retain a charge as one or more cells will become 'worn'. Unless your appliance has a 'smart' charger circuit, leaving the appliance always plug-in will greatly reduced the batteries pack life due to overheating/overcgarging.
Unless you can test and replace as required the individual batteries, it may not be a cost effective solution to replace the batteries.
Hope it helps.
Jul 27, 2010 | Black & Decker SPV1800 Handheld Vacuum
My phone wont charge unless i am holding it at a certain angle with a certain pressure... i got a new charger thinking that was the problem... but it does the same thing. unless i'm holding it, it won't...
its may be your chager point problem after changing charger is not done then you will change your ph charger point i think then the problem will remove
Jul 15, 2010 | Pantech Matrix Cell Phone
When I turn the camera on it only stays on for about 5 seconds and then automatically turns off. Re-charging the battery does not help. Is this the sign of a defective battery? Current batteyr is 2 years...
Unless it's turning off while you're still taking photos, I believe this is similar to many electronic devices (i.e. laptops), which turn off after a certain period of inactivity so that the battery won't die when you accidentally leave it on when putting it away etc.
Jan 03, 2009 | Olympus Stylus 720 SW Digital Camera
I have a range rover p38, and the front passenger side heater only blows cold air ?
Almost certainly blend motor failure. The heater matrix has several blend motors which divert hot or cold air the vents you select. The problem is, the buggers fail. Their £200 each and a nightmare to get to. Unless you actually want to remove your entire dash i suggest you put up with it. I understand a garage will charge about £1500.
Nov 09, 2008 | Land Rover Range Rover Cars & Trucks
Ellas Mam Wont *** I Did make Her Fall Asleep But She Wpnt Ring Or ***
After you put Ellas to bed you must leave the bedroom and click on the moon for night to come in morning go back upstairs and wake Ellas hopefully after you dress her her parent will come. Hope this is helpful?
Aug 06, 2008 | Nintendo DS Lite Console
LG Vu CU920 Cellular Phone Logo
122 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
