ASUS Transformer TF103CX A1 BK 10 1 Inch Tablet Black Logo
N
Nathaniel Jones Posted on Aug 22, 2016
My school gave what i think is an asus transformer tf103c and when i charged it the transformer said it was full at 85%. Does anyone know how to fix this?
What does a bright orange triangle( with a ! in the middle of it),mean when tablet will not on ?
Thread: Android bot laying down with exclamation mark - Asus ...
www.transformerforums.com > ... > Asus Transformer (TF101) Help
Apr 7, 2012 - 10 posts - ‎5 authors
Hello: With the tablet powered off I press down "- volume button" and ... Guys - you can only do a cold boot or factory reset through the .... No worries I've sounded grumpy occasionally myself - even big, bright, yellow, grinning me ... dead android with redtriangle ... what does an android avatar laid out mean.
Warning triangle and thermometer on charge s... ' Samsung Galaxy S ...
forum.xda-developers.com/.../warning-triangle-thermometer-charge-t15...
Apr 13, 2012 - 5 posts - ‎4 authors
I also can't turn the phone on unless I go to Recovery and reboot the system that way.Does anyone know what this means? Thanks.
Print spooler not working google cloud print
https://support.google.com/cloudprint/?hl=en#topic=4456286
Nothing happens when I rub my mouse keyboard on my Asus Transformer T100. How do I get it to be visible
Ok I have been thinking about your problem. How long did you actually charge your Asus Transformer?
You might need to charge it about 8 hours minimum to get it to work efficiently. Try that and see what happens.
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
I can not turn on Asus Transfomer TF201
have you tired charging it?? because it could just be dead. if that doesn't work then it's probably broken and you should take it to a computer shop, you now the ones who fix computers the'll know more than me. LOL
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
2answers
My asus transformer pad isn't charging ?
IF cable is not an fault, try to replace the power adapter, even if fails try in the desktop or laptop rear USB ports. Hope this may helps U
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Broken charge port on asus transformer prime
take to your local repair shop it will cost £25 to repair
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
