picture is too dark, replaced the lamp, but the picture still too dark
Comments:
Jul 18, 2009
- Hello There,
Thanks for the reply, I tried to adjust the picture control, its on Vivid, Brightness is all the way up, still too dark. and what is the flyback? if you don't mind explaining it further.
Thanks Again
Sam
It is stuck on channel 5 - If I go to any other channel it says "channel not available". ...
(More)
It is stuck on channel 5 - If I go to any other channel it says "channel not available". I need to get it to channel three so that my Rogers HD box will work
Panasonic DLP PT-56DLX75--Authorized service tech replaced entire assembly in back. Said lamp was...
(More)
Panasonic DLP PT-56DLX75--Authorized service tech replaced entire assembly in back. Said lamp was still ok. Now even after this service, power indicator lamp flashes orange 6 times after TV on for about an hour. When picture is on, shadows of faces and dark walls look pixelated. Picture not as good as before problems surfaced. Thanks for your help I have the same issue on a Panasonic PT-56DLX75. Works great for about an hour then shuts off and displays a yellow/orange flashing light at the power button. I can unplug it and get it to come back on, but a few minutes later the problem returns. I've tried cleaning it out and making sure it wasn't a heat issue but with no change.
(More)
My son was watchind tv and it went to a double picture showing in a curved format anyone know what...
(More)
My son was watchind tv and it went to a double picture showing in a curved format anyone know what part i might need.
