Question about Pioneer PRO-520HD 53" Rear Projection Television
To get the split screen feature do I have to connect more than one input to the Pro 520HD
  • 864 Answers
Yes
Posted on Jul 18, 2009
Red light on back of pioneer pro-520hd
The most common issue on this model is the power board develops all kinds of bad solder connections--have to remove and in most cases hand solder the entire board.
Dec 16, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Dim/dark Picture
The model indicated here is rear projection that uses three picture tubes.
If rear cover is removed--can be done by removing entire front screen but there are hazards like damaging the screen---with rear cover removed clean the lens in the three round cyclinders which point up and are hard to miss===
They are the light source for the picture---there is if you look up inside and to the rear a mirror but unless grimy it rarely needs cleaning.
clean the lens with a lens cloth or even a paper towel with glass cleaner sprayed on the towel.
Jun 12, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Will not go on s- stays in stanby mode
It is staying in stand by mode because a usable video signal cannot be found, I would first try changing your cables and possible y even change your video inputs example switch from Componet to HDMI or SVIDEO or visversa.
Sep 04, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Can this be connected to Apple TV?
through HDMI it should be able to im not sure but you can go to
www.google.com
search-the name of your (tv-Pioneer PRO-520HD-specs) the specs should let you know if you can or can't but most likely you should be able to
Jan 08, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Hi my name is mario, i have a pineer pro 520hd pro and my pwer suply is burn, so i was lookin for a replace were can i find it . thanks for your help.
Hi Mario, you might check with Electronix at http://www.electronix.com Click Television Repair in the left column. Best...
Oct 08, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Colors are skewed on Pioneer Pro-520HD
you can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Feb 20, 2009 | Pioneer PRO-520HD 53" Rear Projection...
Is the RGB computer-like jack at the rear of the Pioneer PRO-520HD projection TV a digital input like a DVI input? I'm trying to use the TV for BluRay discs. Chris Fox
The RGB input is like a computer monitor input, and may handle HD. I would recommend using component video instead for ease of use, but also most TVs will only handle a couple resolutions, but your component jack should handle 480i, 480p, 720p, and 1080i giving you flexabilty and a comprable picture.
Dec 06, 2008 | Pioneer PRO-520HD 53" Rear Projection...
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
PRO-520HD Tv will not stay on
you may have short in convergence circuit but this is a job for experienced tech after replacing ic's need to get in to settings and and is kind of complicated
Mar 18, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer PRO-520HD 53" Rear Projection Television Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
