Canon now includes a 'smart'chip in the cartridge to deter refilling.
Buy NEW PG40 and CL41.
This is actually a very easy fix. Two absorber pads are located on the
right side of the printer, under the ink cartridges. With the printer
on, lift the top to expose the cartridges. They will automatically move
out of the way. You can move them to the left side by hand if the
printer is not on. You will probably need a flashlight to see the pads.
They each sit in a rubber retainer. The pads can be removed very easily
and cleaned. Take the pads out of the retainers with tweezers. They
clean up nicely with warm water but you can use something like Simple
Green if they are stubborn. It is best to use a spray bottle (on
stream) and blast it through the pad until it is white. Sometimes just
putting it under a running faucet will do the trick. If there is ink in
the rubber retainer after taking the pad out, it can be cleaned up with
a paper towel. Put the pads back into the retainers and you have
successfully cleaned the ink absorbers. Now you may have to reset the
error message so you can get back to printing. This is how to do it.
How to clear E27 Code
* With the printer powered off but connected to a power source, press
the Power button while pressing and holding the Stop/ Reset button.
* When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop / Reset button
(regardless of order), the printer will move into a service mode.
(Waiting for menu selection)
* When the on/off lights in green,
press the Stop/Reset button the specified number of time(s) according
to the function listed in the table below.(Each time the Stop/Reset
button is pressed, the LED lights alternately in orange and green,
starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
* Turn off the printer.( it must be turn off) then turn it on again.
