SOURCE: Olds silhouette heater blows cold air
as long as the engine temperature is normal, i would suspect a clogged heater core, the dex-cool antifreeze is notorious for building up deposits in cooling system. have heater core flushed first to see if it makes any difference
SOURCE: Warm air from dash vents but cool air from defrost
The system just needs to get all the air pockets out if you switched everything like you said look around where the radiator hose meets where you put the thermostat in, there should be something on the lines of a little nipple with a 8 mm bolt on it i will have to pull up the exact setup of your Taurus but its the same general concept your car is fine you just have a big air pocket , what else you can do is while its cold right now and the car isnt running is to go take the radiator cap off the radiator and see if the antifreeze is low now that the car has cold down since you last ran it. If so feel it up top it off in the radiator and it might hurp it self and remove the air pocket all on its own... If you need any more help feel free im always on here id be glad to help more in detail once you try that and look under the hood for the bleeder ( the thing with the nipple on it) Also if you could please rate me i would greatly appreciate it.
Thanks,
Steve
SOURCE: heater /ac
i had this exact same problem with my 98 explorer. your blend actuator (blend doors) are not morking. these are on the passenger side under the dash. getting to them will be dificult, but it can be done. you will need to take apart the heater box, to fix them. (the big black box under the dash).
SOURCE: heater blows cold air ac blows warm air
Your problem is the air temp control blend door actuator is defective and not controlling temp u set. to change/access this part the dash assembly must be removed from the car.
SOURCE: Heater not working, had thermostat replaced no
My 87 Celica had the same problem and it was the solder connections on the back of the heater control panel.
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
Air
Temperature Control Blend Door Failure No Heat
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
