Question about Whirlpool GEW9200L Electric Dryer
It stops with an E1 showing, and now when we try to start it there are 3 fast beeps and no action.
  • htmc3 Jul 18, 2009
    This is model GEW9200LQ0. It looks like there are two thermistors: one with two blue wires ohms closed (with one wire removed). The other with a black wire and a red wire ohms open (with one wire removed). So I guess they are both supposed to ohm normally closed? Second one is bad?
    Glad to know just what E1 refers to.
    Thanks for the help.
  • 3,230 Answers
Error E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel. The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off.
Good Luck!!
Thanks
Posted on Jul 18, 2009
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
My Samsung microwave was giving SE error. I cleaned the contacts. Now it is showing E1 error with constant beep. Pl suggest remedial action.
Constant beep sounds like a bad microprocessor on the main time board. May have to replace the board.
Sep 24, 2017 | Samsung Microwave Ovens
Torpedo FN-10195 Magnetic exercise bike ERROR E1
Contacy the makers to see what the error code means.
Jan 10, 2014 | Sport & Outdoor - Others
I have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
1) adjust the speed sensor, and clean it, and tight the connector very well.see the diagram
2) test the main board output , for input voltage motor, if there are NOT the board is faulty see the block.
3) test the motor for input voltage, if there are the motor is faulty
God blesss you
Sep 19, 2012 | Exercise & Fitness
Washing machine stops, starts filling then beeps
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Tertiary Source: Motor Controller module.(Display Module Phase1 )
Jan 30, 2012 | Fisher and Paykel Washing Machines
My wife was beginning an auto cleaning of our whirlpool range oven [model RF387LXG]. When changing the automatic cleaning time from the 3 hr 30 minute default time to 2 hr 30 minutes, the display began...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%#$^YRGD
Dec 24, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Sharp a/c-#AF-S85FX
The e1 code is operated by a timer which stops the machine every 720 hours of run time. There are 2 procedures to reset this.
1) unplug the machine. Hold down the power button while plugging it back in and waiting for a beep of about 5 seconds duration. Release the power button. Unplug the machine again. Resume trying to use it as an air conditioner.
2) unplug the machine. Hold down the Mode button while plugging it back in and waiting for a 3 second beep. Release the mode button. The machine will start. turn it off by pressing the power button. Resume trying to use the air conditioner.
If these do not work, the "clean filter timer" is broken and will require you to replace some parts.
(Aren't you glad there is a computer is almost everything?)
Jul 24, 2008 | Heating & Cooling
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Whirlpool GEW9200L Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
