Question about Texas Instruments TI-30XA Calculator
The screen of my TI-30XA calculator recently went blank. The screen faded over a period of two days, with no signs of fading before this (I have had it for 5 years). I tried "recharging" it in the sun, but it did not light up again. Any suggestions? Thanks!
  • Texas Instru... Master
  • 8,073 Answers
After exposing the solar panel to the sun press the [ON/AC] key.
Hope it helps.
Posted on Sep 15, 2009
Screen fade and return
weak battery, or loosen display.....
change battery.... if doesn't help,. open device and check screews that are holding display, if it's loosen, tight it up
Apr 12, 2014 | Texas Instruments TI-82 Calculator
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
Screen fading numbers not clear
Usually that is a power problem....change the batteries if your running on battery and if not then the transformer inside is going bad...
heatman101
Sep 03, 2010 | Texas Instruments TI-30XA Calculator
Simplifying fractions on the TI-30XA
Two ways:
1) hit the equal sign
2) hit 2nd and [d/c] (you can do this multiple times to see it as the most reduced improper fraction or as a mixed fraction)
Mar 01, 2009 | Texas Instruments TI-30XA Calculator
TI-85 Calculator's LCD Display if faded
I did a little research on the Texas Instruments Website  and here is the answer.
Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=85103&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG57C2FA762C0BEC303F5B74A9018844AE124A5516274A019AFE22BA90B20
Jan 13, 2009 | Texas Instruments TI-85 Calculator
Batteries
Unscrew the six small screws on the back with a small phillips cross head screwdriver (an eye glass screwdriver works fine), then carefully prise off the back using a flat blade in the two slots at the top of the calculator.
Keep it upside down or the display will fall out!
You'll see the two 1.5 volt alkaline batteries there, GPA-76 type (flat, round) in mine. Ease them out carefully and replace them, positive side up.
Alternative battery codes (manufacturer dependent) L1154, AG13, GA13, AG76, GP76A, 675HR, LR1154, LR44 per battery web sites, maybe others.
Make sure batteries are seated and display is in its correct position, replace back cover and six screws.
Caveat 1 : You can buy the TI-30XA for about $10-$13 at Staples/Amazon, two batteries will set you back around $5-$7!! But they last a couple years even with heavy use. TI-36X and TI-30X IIS are better calculators and have solar cells as well.....but about twice the price at $17-$25.
Caveat 2: I had one of these where the display faded, replaced batteries, did nothing because circuit board or display was bad. So you could replace batteries and waste the time/money.
Nov 19, 2008 | Texas Instruments TI-30XA Calculator
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Problem
Either battery is dying, or circuit board has gone, or connector cable loose.
You can replace battery by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA for $10 from Amazon, Staples or elsewhere.
Nov 04, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
504 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
