Question about GE WBVH6240F Front Load Washer
Leaks like crazy. Looks like from under it somewhere and from the door.
Need to look at your seal in the front. I have replaced four of them in the past two and one half years I have owened mine. Do not use it if it is still leaking because there is electronic conrolers under there and if they short out its a prety penny to replace them. I hope this helps you.
Posted on Aug 01, 2009
Door lock
Could be a wire left off the starter .
Apr 21, 2017 | 2006 Mitsubishi Eclipse GS
Help, my power washer is LEAKING!!!
was water left in the washer for the winter and it froze ?ice expands and brake stuff like that
May 20, 2012 | General Garden
Leaks onto the floor
With or without a load in the dishwasher, start the wash cycle and watch the whole thing. Inspect around the door to see if water is seeping through the seal. If no water is leaking around the door, then there may be a cracked hose line somewhere else.
Apr 12, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
What do I do for a major oil leak? I just drove home and now I have a pool of oil under the car! Its leaking like crazy!
You probably blew a seal somewhere. I would try to pinpoint where the majority of the oil is coming from then replace that seal. A lot of times oil pan seals, drain plugs, rear main seals and valve cover seals can cause large oil leaks.
Nov 18, 2010 | 1989 Jeep Cherokee
I have 2 leaks on my renault scenic, one comes in
why is wet came from inside driver floor inside box store there is water was inside car model ireuault scenic 2004
May 12, 2010 | Cars & Trucks
1993 honda accord ex drove in rain, belt squeeled under hood and dash lights { ie.. no idiot lights} went out and car stalled but stayed on now no spark no lights, radio still works but no clock either...
you have gotten water on a 2" x 2" circuit board box in the trunk drivers side near your rear taillights. this has to be replaced. it is only available at dealer. email me back if this fixes it. drewshouse62@yahoo.com. i had the same problem on my 98 accord.
Jan 23, 2010 | 1993 Honda Accord
I have a water leak somewhere. Both the driver and passenger sides have about 1/2 inch ofwater on the floor . The wibndsheild looks like it has a good seal. Where else can I look? Thanks
Lift your hood and check the cowl where the engine compartment meets the cab, check the door seals, check the level of your radiator and hope it is not low as that could mean your heater core is leaking.
Nov 05, 2009 | GMC Sonoma Cars & Trucks
200 Jeep Laredo..Air is cold and fan is blowing,
there is a blend door actuator for the laredo and if is bad the air wont come out here is a pic of what it looks like and how to get to it
The single zone heater-A/C system is equipped with a single blend door actuator. The dual zone system has two blend door actuators, one for the driver side blend-air door and one for the passenger side blend-air door.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the glove box from the instrument panel.
  3. Remove the three screws that secure the blend door actuator to the passenger side of the HVAC air distribution housing .
  4. Remove the blend door actuator from the air distribution housing and disconnect the HVAC wire harness connector from the actuator.
  5. Remove the blend door actuator from the vehicle
to instal
  1. Position the blend door actuator into the vehicle.
  2. Install the blend door actuator onto the passenger side of the HVAC air distribution housing . If necessary, rotate the actuator slightly to align the splines on the actuator output shaft with those on the blend door cam .
  3. Install the screws that secure the blend door actuator to the passenger side of the air distribution housing . Tighten the screws to 17 inch lbs. (2 Nm).
  4. Connect the HVAC wire harness connector to the blend door actuator.
  5. Install the glove box into the instrument panel.
  6. Reconnect the negative battery cable.
Sep 09, 2009 | 1998 Cadillac Seville
Vacume leak under dash. Sounds like door opening
You got it right, there is a 'door' that opens and closes under the dash to change cooled or heated air flow to the interior vents. A vacuum line either disconnected, or is leaking somewhere, and is most likely responsible for the lack of a/c. You are going have to hunt around to try and find where the leaking/disconnected line is to repair it. It's not going to be a fun job. You can access diagrams and info on your car (for a fee) at alldatadiy. Look under HVAC system to see the info you need. Good luck.
Sep 03, 2009 | 1998 Lincoln Town Car
Leaks under left hand side of door; I've installed 2 new gaskets in last 2 weeks & new float switch; doesn't leak underneath
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Jan 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
GE WBVH6240F Front Load Washer Logo
74 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
