Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a 2000 HD sporster 1200 custom. The left turn signals (front and rear) along with the hazard lights do not work. The right turn signal works and the cancel of the left turn signal works when turining on the right turn signal. The bulbs are good and the switch for the left turn signal is good and has been tested for voltage. Any ideas on why the left signals and hazard lights just stopped working?
  • 116 Answers
First just because a bulb looks good doesnt mean it is couple of peices of wire and a battery is all you need to test the bulbs secound thing the turn signal cancel works on the amount of flashes regardless of which side is on note:any bulb thats bad none on that side will work
Posted on Jan 15, 2010
  • makeitfast57 Jan 15, 2010
    last line meant to say will NOT work
My rear turn signals are not working. front turn signals work rear parking lights work brake lights work
In the diagram for rear lamp, the top wires are voltage, the bottom black wire is ground. The brown wire on either side should be tail lamps, goes hot when you turn on the headlamp switch. The other top wire on either should be for turn signal. With everything turned on, is there voltage on that wire?
Because the front works and the rear don't, possible wiring circuit problem? The voltage for turn signals comes from bcm. The bcm knows when you turn on turn signal switch, either side, then the bcm sends voltage to turn signal lamp at the rear and front.
Oct 17, 2016 | 2009 Chevrolet Chevrolet HHR LS
Diagram sportster wiring
More information would be helpful.
Do any lights work, ie signals, four ways. Does rear brake light work and just not light when front brake is applied.
If all lights are dead did you check the lighting fuse?
Fuse panel is under the left side cover.
Jun 07, 2014 | 2000 Harley Davidson XL 1200 S Sportster...
Rear hazard flashers don't work 1994 Chevrolet Cavalier
Hazard flasher power comes from the 20A S/LP fuse in the fuse block. It is applied to the hazard flasher in the convenience center. Flasher output is applied to the turn/hazard/headlight SWITCH assembly where activation of the HAZARD switch causes flashing power to be applied to the turn indicators and the turn filaments of the front and rear dual park/turn lights. If replacing the fuse doesn't work, trace the power through the circuit. Check for misssing/disconnected ground wires.
Sep 16, 2012 | Chevrolet Vehicle Parts & Accessories
When i turn my 1997 sporster xl 1200s on,all the lights come on but the rear marker light.but the rear turn signals work. need to know ,why my head- light and front marker lights work plus my tail light,...
According to the schematic I'm looking at, your 1997 model Sporty came with front marker lights but not rear marker lights. To make sure, take the lens off of your turn signal light in the rear. Take the bulb out. Now, does the bulb have one or two filaments? If it only has one, then you don't have marker lights.
Let me know what you find.
Ride Safe
Steve
Aug 17, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
Rear turn signal and hazard light don't flash (left side only)
The rear left turn signal bulb must be replaced immediatly before it melts the light socket, if it has'nt yet. Also please verify that the correct light bulb is being installed. because even though many bulbs look the same they are not identical. Installing the wrong bulb can be the begining of many, many problems in the particular circuit
Mar 26, 2010 | 2000 Ford Focus
Runnin lights dont work but blinkers do
The only running lights will be the front. Make sure there are 3 wires going to the front turn signals. If not then you have a set of rears on the front. The wire color for the running light side is blue. That can be ( or should be ) attached to an Orange/ white wire ( that is a typical key on hot for Harley ) I would also double check the ground on them as well, since the turn signal can actually pick up a ground by back feeding through itself, but would still not let the running light to work
Jun 27, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
Driver side signals only work when headlights are OFF
What may have happened is either the headlights wiring or the parking lights wiring somewhere along the wiring fused to the left turn signals wiring. Depending on if the turn signals go on when you put the parking lights on or the headlights on.
If the signals come on when you turn on the headlights than you only need to locate the light green wire that comes off the left turn signal harness.
Next follow that wire the entire way back to the firewall looking for another wire fused to that wire as you go.
If there are no signs of this you need to continue looking on the other side of the firewall all the way back to the turn signal and hazard flasher unit which is a black box that connects to a black harness located next to a grey harness behind the knee bolster.
But if the signals come on when you turn on the parking lights than you will also need to check the wiring from the rear left signal and follow that light green wire all the way back to the turn signal and hazard flasher unit.
This should fix your problem, but if not than your problem may lay within the the wiring between the turn signal/hazard switches and the turn signal and hazard flasher unit.
Also you may have a burnt circuit in the junction block. This block is where the light green from the rear left signal and front left signal meet. Don't have a description but if you cannot find it let me know and I will go out to the yard and look myself and let you know.
Apr 22, 2009 | 2004 Dodge Intrepid
2000 1200CC SPORTSTER. FRONT TURNS SIGNALS WORK BUT REAR SIGNALS WONT WORK. HARNESS WAS SHORTED BY LAST OWNER. HARNESS IS WORKING FROM UNDER SEAT TO REAR TURN SIGNAL LIGHTS. BULBS GOOD.
Hi Raflakenhe, check for continuity between the turn signal module and the rear fender tailight wiring harness especially the connector for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Apr 11, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
384 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
