Question about Hoover Dryers
Loud bang, smell of burning
Hoover Family HD7 Tumble Dryer - Loud bang, blown fuse, smell of burning
  • Anonymous Mar 16, 2014
    BRAND new dryer bangs really loud! Never been used. What could it be?
    Scholar:
  • 78 Answers
Hello sir,
there must be a electric short circuit happened in ur machine, plz check all d wires, b4 replacig the blown fuse.
or else u must have connected ur machine to a wrong rated power terminal.
plz isolate ur body from the machine while fixiing this problem, n ensure that there is no leakage of current after u fix it.
thank u!!
if my solution is currect then plz vote me sir
Posted on Jul 18, 2009
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Hi. my BEKO condensor sensor dryer cuts out the electric mains flip switch when i turn it on. Have checked the fuse and lead no damage, checked socket and it works other appliances. What would cause t
The same happened to our Beko DCU8230 last week still under 1 year warranty, loud bang, burning smell and trip switch flipped. Beko Engineer who called said mains suppressor capacitor had blown.
Aug 27, 2012 | Dryers
Whirlpool dryer makes loud banging noice&smells like somethings burning
let the maintenance guy from your brand company check it quickly not to cause any dangerous problem to you or your family or other assests.
Jan 09, 2012 | Whirlpool Dryers
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 16, 2011 | Samsung DV218AEW Electric Dryer
We have a Hoover Elecron Dryer De Luxe D6292 and the drum will not turn. There is a loud clang and the belt is no longer on the pulley arms. We have tried replacing the belt, but each time the drum rotates...
here is a picture of some belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Now there may be a problem with the drum rollers/glides or idler arm:
rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
idler pulley(third on list right under motor):
Hope this helped Tim
Jan 09, 2011 | Dryers
Our dryer has started making a loud thumping sound and smells like rubber burning?
It sounds like you your dryer may have a bad Blower Wheel, which is causing the banging noise that you are hearing (especially if the banging noise continues for a few sections after you turn your dryer off).
Hope this is helpful.
Jan 16, 2010 | Microsoft Windows XP Home Edition
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
DBXR453 GE Electric Dryer - Noisy
I have the same dryer, with the dryer empty open the door and try to push the basket up, if it has lots of play in it then you should check the "bearing drum" which is attached to the front panel. this machine doesnt have bearing on the back of the drum. it rides on plastic sleaves called slide drum. they are on the inside of the front dryer panel. only 4 screws to remove and check
Mar 30, 2008 | GE DBXR453EV Dryer
Dryers Logo
241 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
