Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 1050 changed oil now its wants me to change oil again and it smokes really bad now to much oil or too little
  • 202 Answers
The 1050 holds 57.5 oz slightly less than 2 qts 64 oz. the filler stick is marked. shiould be over the add mark not over the full mark
Posted on Jul 18, 2009
Cub cadet 1050. Changed fuel pump, get oil past the fuel filter but not into carburetor. Won't start. Any ideas
Hi have U checked the needle ,& seat in the carby it is possible it's jammed closed if so it will not let petrol in .. Cheers
Sep 11, 2016 | Cub Cadet Garden
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
Jun 18, 2016 | Cub Cadet Garden
What does white smoke coming from a cub cadet lawn mower mean
Most likely the valve seals or the rings are bad and the engine is burning oil.
Oct 06, 2014 | Cub Cadet Garden
Why is the oil light flashing on my cub cadet riding lawn mower model 1050 but oil level is ok
Check your owners manual but probably telling you it's time to change oil
Sep 25, 2014 | Garden
Cub cadet troubleshooting
unhook battery wait 20 secondes hook battery back up fault should be gone or you have a bad oil sending unite cost 20.00
Aug 28, 2014 | Cub Cadet LTX1045 2009 and After Deck Belt...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My dad just changed the oil in a 1050 25hp tractor and an oilo light keeps flashing. what do we do?
If the filter screws up into the base, remove the filter and check to see if there is oil in the filter. If not pour oil into the filter and reinstall. It sounds like the filter needed to be primed.
I would like to hear how you made out. Good luck.
Jun 12, 2011 | Cub Cadet Lawn Mower Hydro Filter Replaces...
Finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Jun 12, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
575 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
