Question about Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1
We have a hayward H100IDP1 pool heater,,we can hear fan come on,,but does not ignite...Was working fine beginning of season,,,notwont ignite..Pool filter is fine andrunning well,,could it be a pilot light? Actually I noticed the last time it ran westarted it again andit did fire up but turnedoff. could you please advise us what to check and how to go about it..
  • 864 Answers
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are Ok then the unit may have gone off on high limit the last time you used it or the gas valve coils may have to be replaced. If there is a reset button for high limit press it. If not then the safety sensor for high limit may have to be replaced. If the unit fires up but does not stay on then the gas valve coils may need to be replaced.
Posted on Jul 18, 2009
Pool heater Hayward H100IDP1 power to gas valve problem
possible gas valve if when quits is there gas pressure if ok make sure not overheating check manual bypass valve
Sep 01, 2012 | Hayward 100kbtu Pool Or Spa Propane Gas...
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
Hayward H100IDP1 steeming pipe
english is good th epipe taking the steem out has a reason to be may be the heater is over heating or is has been left open by accident but here go if open may the heater exchanger is plug the pipe has been installed reverse or assembly valve is not good any more , is the flow to slow? psi at the filter must 10-18
Jul 28, 2009 | Hayward 100kbtu Pool Or Spa Propane Gas...
Hayward 100kbtu Pool Or Spa Propane Gas Heater H100idp1 Logo
348 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
