Question about Hitachi 43F300 43" Rear Projection Television
I need to remove screen protector on my hitachi 65" big screen tv
  • 250 Answers
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).
Once this strip is removed, you should be able to see a gap (~2mm) between the top of the protector and the frame. Pull the middle of the protector toward you (you may need to hook it with something like a chrochet hook to get it out to where you can get a finger on it). Pull out one side of the protector, then work it loose fromt he bottom. (If it is stubborn, you may have to loosen the bottom frame. Take of the speaker grill, then unscrew the screw on the bottom of the surround for the control panel and pop the surround out. Then there are 3 screws that hold the cabinet frame {might me different for the 58B} and beneath that, 3 screws that hold the bottom of the inside frame. Once those are removed, you should be able to flex the inside frame enough to loosen the protector.)
Installation is the reverse. There are two grooves (at least on my set), and the protector goes in the rear groove(!) (same as the screen itself - first time I tried to put it in the unused groove closer to the front of the screen, and that iddn't work). The black plastic retainer strip goes in the front groove.
Posted on Jul 18, 2009
Where is the projection bulb on my Hitachi 65s700 65 inch
Hi Anonymous,
There is no "Projection Bulb" for this model. It as a 3 tube Rear Projection TV. The most common problem is Convergence Failure as in the link below.
Calgary Hitachi Big Screen In Home TV Repair Service
Robert
Nov 12, 2015 | Hitachi Televison & Video
Removing a screen protector on a Hitachi 57F10A
You might try Hitachi for the service manual with full breakdown.
Basically the entire front screen unit comes off from the front in one piece, then inner two screens come out--carefully! and then frame needs to be partly pulled apart to get out screen from rear as it is in a slot all around the frame.
Apr 10, 2012 | Hitachi Televison & Video
How do i remove a protection screen on a hitachi tv model 65F59
Remove the Front Bootom Panel Then under the screen is serveral screws holding Screen on remove them and Screen Lifts Up and out.
Oct 18, 2011 | Hitachi 65F59 65" HDTV
Need to find a new screen for a 65" hitachi tv,
The screen part number is UX26083 but it appears it is no longer available
Jul 29, 2011 | Hitachi 65F59A Television
I have a 65" hitachi
there is a mirror inside the projector box, contact www.partstore.com or andrewselectronics.com. you will need a complete model number when you research the part number for the mirror.
Nov 03, 2010 | Hitachi 65F59 65" HDTV
Projection screens interchangeable?
it should work fine, its worth a shot
Apr 12, 2009 | Hitachi 65F59 65" HDTV
Removing a screen protector from a Hitachi 50UX58B Projection color TV
There is a black plastic strip that fits into the groove at the top of the frame holding the protector and front screen. Pull that down and out (you might need to pry a little to get it started). The attached picture shows the strip partially pulled out at the right edge (photo depicts the top right of a 58K - with a wood cabinet).ea84b4b.jpg
Mar 22, 2008 | Hitachi 50UX58B 50" Rear Projection...
Both screens for 65" hitachi projection tv
Since you don't say the model number, go to partstore.com and order them by model # and "screen"
Jan 14, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
BROKEN SCREEN
I had the same problem I had to get a UX26083 from Ued.net. now i can't install it!
Dec 30, 2007 | Hitachi 65F59 65" HDTV
Hitachi 43F300 43" Rear Projection Television Logo
202 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
