Error codes: dC, dE, dF, do, d0, 1 DC, and 1 dF These error codes indicate a problem with the door, most commonly the door latch or the sensors. When these codes appear, it generally means you need to check your door to see if it closes properly.
Samsung Dryer Error Code = FE Error Condition = Power supply out of range (frequency) Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board. Parts For Replacement = Electronic Control Board
is there any error codes?just had a dryer with an he error and found it had a bad thermistor located on the back of the blower wheel housing.send model number and any error code
1) this error indicate error with the door swtich, test the switch for open or defective see the video + diagram and troubleshooting. However run the test diagnostic. 2) test the timer, contacts dirty, loose wires, break or burn repair wires. 3) the motor can be faulty, for winding burn or overheating need repair or replace
