CANNOT COMPLETE CONNECTION WITH SOME OF MY CONTACTS,
INCLUDING THE ECHO/SOUND TEST CONTACT. SOMETIMES I GET A MESSAGE THAT CALL COULD NOT BE CONNECTED OR WAS CANCELLED , OR SYSTEM IS BUSY, TRY AGAIN , AND OTHER TIMES, IT RINGS ONCE THEN IT GOES INTO HOLD MODE, AND WHEN I SELECT RESUME IT DOES NOTHING.
I have now discovered that when this was bought it had the latest software installed which I checked, now there is a new software release from Netgear, I installed this and the problem has gone, it is a shame that Netgear does not notify its customers that this problem will occur, instead it has cost me time and money in abortive calls. Having requested help from Netgear in 72 hours they keep sending emails "We are looking into it and a Technician is on the case"! About as much good as a chocalate teapot.It seems that you have to resolve everything yourself with the help of the internet, thank god for that.
Was this helpful?
Yes
No
Solution #2
posted on Dec 24, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try checking and resetting factory and default settings.
didn't get wallmount with it , just got new pones for xmas and no wall mount come with the base,...
(More)
didn't get wallmount with it , just got new pones for xmas and no wall mount come with the base, alto it says it con be wall mounted.
My calls get connected but I can not hear the answering party and they can not hear me. Is that a...
(More)
My calls get connected but I can not hear the answering party and they can not hear me. Is that a software issu? Any ideas how to solve this problem?
unable to initiate handset or reset Back to square one to set up handset from the getgo. Can access...
(More)
unable to initiate handset or reset Back to square one to set up handset from the getgo. Can access menu on handset by powering down base unit When entering "reset all"(from advance ) says "unavailable" repowering base set at this point returns automatically to "system is starting up" then"Searching ....please wait " -----A continuous loop!!! would appreciate your help to solve this so I can use this device Thanks Mickeydoo PS As I intend to use this phone in Mexico any special advice Country code 52 local cell phone no. etc?
seleccione dar de alta al telefono y ahora sale registrar a nueva base y dice registro fallo. Que...
(More)
seleccione dar de alta al telefono y ahora sale registrar a nueva base y dice registro fallo. Que puedo hacer no se siente tono.
