Question about GT Bicycles Cycling
The frame is snapped where the gears are attached on the back wheel
  • 31 Answers
Well simply buy a new one or weld it back on?
Posted on Jul 23, 2009
Why does steering slip turning left?
broken teeth on the steering gear (attached to the steering rod) or the steering plate (the one that turns the wheels) follow the steering rod from the steering wheel down to the frame, if it goes THRU the frame look underneath the lawnmower and youll see which one is messed up, just replace the one that has the broken/worn down teeth, hope this helps
Jun 02, 2015 | John Deere Garden
Nishiki bravo bicycle will not engage gears when pedalling
has the cog seperated or snapped off the wheel as in can you freeturn the wheel and make the cog go around or does the wheel spin but the cog doesnt move,
if so your up for a new rear wheel/cog
Jan 28, 2013 | Cycling
Need to replace main drive belt for sickle bar
Instructions
Put on your work gloves. Check the frame size for your mower. It will either be a 56-inch frame mower or a 76-inch frame mower. When you have determined the frame size, adjust the tractor's rear wheels to the mower's frame size. For 56-inch frames, adjust the rear tractor wheels to 56-inch centers or less. The same rule applies for 76-inch frames.
Back the tractor into a position where you can align its left lower link to the mower's lift link pin. Attach these two parts together and secure the connection with the tractor linchpin.
Roll the tractor and adjust the leveling crank until the tractor's right lower link can be attached to the right link pin on the mower. Use the tractor linch pin to secure the connection.
Attach the upper link from the mower to the lower hole in the tractor rocker arm by using the link pin.
Start the tractor. Using the hydraulic control lever, lift the mower frame assembly slightly and move the mower to the left to allow attachment of the left stabilizer. Place the stabilizer guide under the tractor's left lift link. Position the clamp over the link and tighten the nut firmly
Depending on the tractor type, install the clamp plate or push rod anchor assembly onto the left lower link. Install the push rod on either the clamp plate or anchor assembly.
Shift the mower assembly to the right to attach the right stabilizer. Place the stabilizer guide under the tractor's right lift link. Position the clamp over the link and tighten the nut firmly.
Raise the mower using the hydraulic control, then attach the mower lift spring to the spring links with the pins that have been provided. Lower the mower assembly and turn off the engine.
Remove the tractor power takeoff (PTO) cap and connect the splined end of the mower's drive shaft to the PTO shaft. Secure the connection with the snap coupler found on the yoke.
Rotate the leveling crank to lower the frame, ensuring that it is parallel to the ground. Use the leveling crank lock to secure the crank lever.
Jul 15, 2012 | Vacuums
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    Where is the gear box on a oldsmobile alero 2004 located
    well on your car they do not call it a gear box . They use what they call a rack and pinion system for the steering . that is located near the fire wall (back of engine compartment ) bolted to the frame and has the inner and outer tie rods on t it and connects to the spindle/wheel assembly
    Mar 06, 2011 | Oldsmobile Alero Cars & Trucks
    OW DO I FIT THE BASKET TO THE QUINNY BUZZ. TERE ARE NO TOOLS WITH IT?
    You take the front wheel off and slide the brackit that is the front of the basket into the frame,put the wheel back in and attach the velco straps to the back of the frame.
    Hope ive explained it right.
    Mar 07, 2010 | Quinny Buzz Three Wheel Stroller
    Chain has become loose and will ride off gears while in use
    If its a singlespeed:
    Examine the tightness of the bolts that attach the axle to the frame by loosening then with a wrench. If it was loose that could have been the problem.
    Now check the alignment and equal spacing of the wheel inside the frame. Pull the wheel back in the dropouts so the chain has an inch or two of looseness. Lightly tighten the bolts and check again and crank the wheel with the pedals and spin. Check the chain and equal alignment of the wheel. Tighten the bolts that attach the wheel to the frame.
    If its a quick release, make sure that when tightening you apply a good amount of force to close the lever at least 90 to 100 degrees. And do all of the above.
    Feb 09, 2010 | Cycling
    Back seats legs will not retract.
    Most likely the problem is due to the little white wheel inside the pivot point on the seat. This little white wheel holds the other end of the cable which is attached to the legs. This wheel likes to snap in half - and is a noted problem on the Ridgeline (just ask a dealer). Want even better news? You CANNOT buy this part unless you purchase the ENTIRE seat frame for a mere $325. You can purchase EVERYTHING else in the assemble but this cheap plastic wheel. Sounds fishy but that is what Honda has decided to do to their consumers. Calling the Honda customer service number won't help you so don't bother!
    Jun 10, 2009 | 2007 Honda Ridgeline
    How the hell does the skirt go on this piece of ****?
    Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
    Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
    Zip zap
    The little blue gear - not the one attached to the rear axle - is easy to fall off when the axle is removed, but easy to put on - if you know the trick. Once the rear axle is off, gently pry the chassis from the body using a flat screwdriver and prying between the tab on the bottom and the body. The body will snap from the chassis. Now, on the drive ('driver', for the USA) side, you'll see a small black nub (actually the drive gear attached to the motor) next to a small silver stub. The blue gear that fell off goes on that silver stub. Here's the trick...angle the blue gear so that it engages the black stub/gear 1st, then push the blue gear onto to the silver stub. If you try to get the blue gear attached without angling it, the black stub/gear blocks the reassembly. Carefully turn the car over, attach the axle with the wheels/tires, then reassemble the chassis/body. Good to go!
    Jun 01, 2008 | DBX EQALIZER, DUAL 31 BAND, INPUT AND...
    Cycling Logo
    Top GT Bicycles Cycling Experts
    Michial Gueffroy
    Ed Hauk
    Ed Hauk
    Level 1 Expert
    Donald Ayers-Marsh
    Are you a GT Bicycles Cycling Expert? Answer questions, earn points and help others
