Question about Fishman Full Circle Upright Bass Pickup Professional Microphone
Cable break! My cable that run from the wheel to the RCA connector has break, last weekend, during a soundcheck (a roadie mis-understanding...) well at the wheel attachment. I need to repair my pickup, replacing the cable or cut-of the damaged section. How can I do? Thanks, Andrea
  • 36 Answers
1. clear cut off the damaged section,
2..solder or ideally wire-wound the connections,
3. insulate the wires with plastic tape, or plastic sheet,
4. shield the wires with aluminum foils,
5. wrap up the outer.
6. done.
good luck
pc-cook
Posted on Jan 25, 2008
Wheel sensor location for a 2008 jeep patriot. I understand that its located on the front right wheel,output from the transaxle
the one that has wires, ABS uses an electronic sender
at each wheel, so look for wires, there, and BINGO.
a wire cable + connector, it is on end of same.
or read the FSM
or read my last post to you.
Oct 19, 2014 | 2008 Jeep Patriot
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have a rca d52w23 no caoax hookup what part do ineed to make my tv cable ready
The model you listed does have a built in tuner so there should be a connector on the back where cable TV would connect to. A very common issue on these sets is the connector often breaks off rendering the tuner useless and therfore requiring replacement of the tuner itself. You can use a cable box and connect it to either the component or composite inputs on the back of the TV. I hope that helps : )
Jul 25, 2011 | RCA D52W23 52" HDTV CRT TV
Can you simplify hook up , trying to hook up with manual and more difficult understanding, want to conect to TV only if possible
The first thing you want to do is run a standard RCA cable from the reciever's Monitor Out to one of the TV's Video In ports so you can see the On Screen Displays from the receiver.
Not knowing what your TV has for connectors: For minimal stereo / low-fi video: If your TV has RCA jacks for L and R audio, run them to AUX In; run the TV's Video Out to the receiver's standard Video 1 In . If you have a cable box, you could run its corresponding cables to the same places for TV viewing.
If your cable box has digital audio outputs, use them instead (best sound, multi-channel) - connect to one of the Digital In's that matches the type and assign it to TV or Cable. Use the Component Video from the cable box, if available.
Jan 23, 2010 | Onkyo HT-SR600 Black Theater System
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
Hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
Dec 28, 2008 | RCA HD52W59 HDTV Projection Television
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
New setup
do you get anything on screen, like the menu or channel number?
Feb 05, 2008 | RCA L42WD250 42 in. LCD HDTV
Fishman Full Circle Upright Bass Pickup Professional Microphone Logo
152 people viewed this question
Top Fishman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fishman Audio Player and Recorder Expert? Answer questions, earn points and help others
