Question about Apple iPod nano
My ipod nano 8g works fine if it is connected to the computer bt controls do not work when disconnect. I have tried to reset and it makes no difference. Is there anything I can do?
  • 77 Answers
  • probably it may due to change in defaullt settings in ipod
  • set the default settings and try again
  • if it still doesnt work check the settings in computer
  • check the connection code if it have any scratch or not
Posted on Jul 18, 2009
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
IPOD 2GB Nano display doesn't work
try pressing the reset button on the ipod. if it still freezes, the ipod has problems
Jul 31, 2010 | Apple iPod nano
Apple ipod 8G Model# A1285 Shows songs when connected to PC, but when I disconnect it show 0 songs. Please Help.
i have ipod modle A1285 when connect on computer all data show but when disconect for pc no show song video and much more why please sulution me
Feb 27, 2010 | Apple iPod nano
IPod going crazy!!!
yo... hook er' up... go ta my computer... right click the icon of your device.. and than click format.. and that should work.
Apr 11, 2009 | Apple iPod nano
IPod 8G Nano completely doesnt work.
ResetTo reset your iPod nano:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 16, 2009 | Apple iPod nano
Ipod nano won't connect to iTrip car system
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 19, 2008 | Apple iPod nano 3rd Generation
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
2gig Nano stuck on hold
The fact that it works fine when plugged into a power source would suggest your battery is going bad (or has gone bad).
Just a guess.
Feb 18, 2008 | Apple iPod nano
Ipod nano 2nd generation won't mount
Could be a hardware problem. Sometimes ipods will not connect to a computer even when everything else is working fine.
Jan 27, 2008 | Apple iPod nano
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
