Question about Kenmore 24902 Top Load Washer
82983130 we have a kenmore top loading washer~ i cant figure out how to get the tub off to fix the water leaking from the bottom!
    Genius:
  • 1,224 Answers
Its how do i put it in words its pressed in need a special tool to get it out
Posted on May 07, 2008
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore top loader leaking from bottom when loading
could be leaking from your drain pump seal, main tub seal which is between tub and tranny, also your outter tub could have a crack in it! i would remove the base to see inside and run it through a short cycle and see if you can pinpoint the leak
Feb 17, 2010 | Kenmore Washing Machines
70 Series Kenmore washer pouring water underneath washer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine leaking water from bottom
Ur tub is dissloge from the frame of the washer. Repaire mans will fix that. Try to do small loads in the futur!
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Kenmore washer leaks water,
on the back of the machine there a two water inlet valves, these are electric solenoid valves and one of them is leaking.  You need to remove the back panel on the washer to replace this valve assembly.  It's a common easily obtained part.
Dec 30, 2008 | Kenmore 24902 Top Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Kenmore washer 110 92581110 top load
if its from the tub then you should fix it! the water seal could be worn out already. it would result to slipping of the belt ans thus poor spinning is produced! poor washing.
Nov 21, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
