Question about Pioneer Avh-p2300dvd 5.8" In-dash Double-din Dvd Av
What would be the reason my touch screen wont work when you touch it but the display is fine and works perfect. I have a pioneer avh - p 2300dvd
Screen is fine but the touch part won't respond
    Sergeant:
  • 238 Answers
Your front screen has gone faulty it's split in two the front panel can be relaced
Posted on Aug 27, 2016
SOURCE:
Touch screen not working for pioneer avh-p4300dvd
you have to clean the debris out of the gap on the bottom of the screen
Oct 09, 2012 | Pioneer AVH-P5700DVD Car DVD Player
I have a black screen on my pioneer avh-p400dvd, all of the touch functions work, i have two of these decks and just memorized where the touch function were, need help if possible
mcdevito75 here, Monitor could be burned out, check all functions specially bright / dark, bring monitor to Staples, Best buy for testing.
Jun 25, 2010 | Pioneer AVH-P4000DVD Monitor
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
The screen is so dark i can barely make out what is on the screen. i hook up a monitor and that looks fine. my stereo is a pioneer avh-p7480dvd
First I would try pressing the DISPLAY button on your remote which controls the display and if that is not it, it's probably the flex cable. These cables go bad after a while and needs to be replaced. you may also contact Pioneer to see if there is a recall on this part as they may pay for it, otherwise you can purchase it on ebay - http://cgi.ebay.com/PIONEER-AVH-P7480DVD-AVX-P7300DVD-FLEX-RIBBON-CABLE-/120529728036
Mar 09, 2010 | Pioneer AVH-P7480DVD Car DVD Player
I have a pioneer avh-p4000dvd everything works just the display is off it would sometimes flicker on and off but wont come back on
there is a reset button on the left of the cd player. u will need a needle to hit the button. once u hit it, the screen will still say caution but when you touch the screen it will go back to your regular settings
Feb 24, 2010 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
Pioneer Avh P5700
might need laser cleaning. try a laser cleaning disc from most electronic shops
Jul 19, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Cd won't eject
After you hit the button...and it beeps....tap on the screen...where the color display is....not too soft but not so hard that you crack it....then it should open after a few times of tapping it and hitting the button. I found this at another forum, and it worked for me.
Jun 10, 2008 | Pioneer AVH-P6600DVD Car DVD Player
AVH-P6500DVD
theres a bad connection on the ribbon cable or its broken or cracked.. I hope you can find one with having to purchaqse a screen Good Luck
Aug 16, 2006 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer Avh-p2300dvd 5.8" In-dash Double-din Dvd Av Logo
289 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
