Refrigerators Logo
Joann Carter Posted on Aug 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove evaporator cover from inside freezer admiral model hmg64184
Leaking water at bottom of freezer
deton8 von Splosion
Level 3:
  • Maytag Master 3,342 Answers
  • Posted on Aug 21, 2016
deton8 von Splosion
Maytag Master
Level 3:
Answers
3342
Questions
6
Helped
927380
Points
54123
Hello Joann Carter,
Make SURE you are electrically UN-PLUGGED.
The repair books tell you to remove all the side rails... pull the screws... Disconnect the temp sensor (if equipped in this area (here you want to start taking lots of pictures))...
The thing is... removing the side rails is usually un-necessary...
A little clever negotiating of the flexible panel... and it can be MANUVERED AROUND (my opinion)...
Further opinion... after a complete open air defrost
(never apply heat (anywhere))... FANS will help... It is possible to blow air UP the defrost drain... & clear it.
Again... Verify you are electrically UN-PLUGGED.
Then negotiate some warm water (never hot) into the
Evaporator-drain pan... Success will be immediately
apparent in the defrost pan...
May take a couple of tries... (straw or flex tubing).
Only failing that... pull out the back panel .
Hope this helps!
GE side by side refrigerator model no TFG20JAWWW 627 litre is occasionally leaking water
Check the drip tray in the freezer section where defrost water drips from the defrost heater melting frost during the defrost cycle. If ice blocks the drain hole in the tray inside the freezer(usually behind the evaporator cover) the defrost water will travel into the bottom of the freezer & onto your floor. Some models also have a second evaporator in the fresh food section. A blocked drain or clogged defrost drain tube can cause the problem.
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
1helpful
2answers
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Water is leaking from time to time in the front of the refriderator. It's not the water feed.
Your problem is likely that your freezer has a blocked drain which doesn't allow the water to drain to the bottom of the evaporator pan under the fridge. The lower backing INSIDE the freezer needs to be removed and the plughole cleared. Best to use a hairdryer and your fingers to remove he pool of ice buildup. Try not to use sharp objects as this can dislodge or break essential plastic pieces. Water should now drain from condensor coils during defrost mode out the drain and into the evaporator tray under the fridge. (melted water is simply evaporated away by the warm air which comes from your compressor and out of the front bottom of your fridge.)
I Hope this helps. Good luck
1helpful
Model HMG611390 serial #10812489UZ, the basket in the freezer was frozen to the bottom, so there was a leak somewhere in the freezer section. Do you have any idea where it may be and how to fix it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
The freezer side of my admiral leaks (collects water and it freezes) at the bottowm. then leaks to the floor. what can I do to fix it?
Have moved into new house with Admiral freezer/fridge/icemaker. Leaks water onto floor from time to time under freezer. Ice maker not connected to water supply so not that.ANY SUGGESTIONS?
Defrost drain is clogged causing this problem. Clear the dfrost drain and pan from inside the freezer section by removeing the freezer back cover plate and you will see from there. No extra parts required just patience.
1helpful
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
2answers
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
2answers
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
