Question about LG Washing Machines
LG F1402 FDS DOOR GLASS REQUIRED, WHERE AND HOW MUCH OTHER DOORS THE SAME?
Do you just need the doors ? If so where would they be shipped to ?
Posted on Jul 18, 2009
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
2012 GRAND CHEROKEE REMOVE DOOR GLASS
how to ? You or them? who is doing this? DIY?
front or rear. left or right.
the fsm covers this.
or for 15 bucks alldata.com? RTM?
wk jeep
qoute
1. Remove the outside rearview mirror (Refer to 23 -
BODY/EXTERIOR/OUTSIDE REARVIEW MIRROR
- REMOVAL).
2. Remove the front door glass (Refer to 23 - BODY/
DOOR - FRONT/DOOR GLASS - REMOVAL). below....
3. Remove the weatherstrip from the front glass run
channel.
4. Remove the nut (2) that secures the top of the
front glass run channel (1) to the inside door panel.
5. Loosen the nut (3) that secures the bottom of the
run channel to the keyed hole on the inside door
panel.
6. Lift the front glass run channel upward within the
door far enough to disengage the nut that secures
the bottom of the run channel to the keyed hole on
7. Remove the front glass run channel from the door.
(back in is longer story) FSM C23 pg 16
and 23page
1. Remove the outer belt weatherstrip (1) from the
front door.
2. Remove the trim panel from the inside of the front
door (Refer to 23 - BODY/DOOR - FRONT/TRIM
PANEL - REMOVAL).
3. Remove the speaker from the inside of the front
door (Refer to 8 - ELECTRICAL/AUDIO/SPEAKER
- REMOVAL).
4. Remove the watershield from the inside of the front
door (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD
- REMOVAL).
5. Using the regulator (4), move the front door glass
(2) up or down as required to access the two window
regulator glass clamp bolts (3).
6. Loosen the bolt in each of the window regulator
glass clamps far enough to release the door glass
from the clamps.
7. Disengage the door glass from the window regulator
glass clamps.
8. Lower the regulator down as required for access to remove the door glass.
9. Carefully rotate the door glass within the window opening and remove the glass from the door through the window
opening.
sorry tool lazy for photos today....
Jul 17, 2012 | 2012 Jeep Grand Cherokee
LG Intello washer Glass in door has craked & I need a new one
LG customer service can help you. Give them a call and select the parts option.
Jan 18, 2010 | LG Washing Machines
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
Ice maker not working no water but the water in door disp.works
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
lkj;fds
Nov 02, 2009 | LG LMX25981ST Stainless Steel Bottom...
LG Microwave Countertop Microwave Oven LRM2060 ST. The glass on the outside of the microwave door is broken. Can you order just the glass from somewhere and can I fix it myself?
Due to the serious potential for RF leakage, these doors are normally sold as a complete unit assembled by the manufacturer. I could only find the door listed at repairclinic.com for about $80. If you wish to repair yourself, the old door comes off by opening it all the way and lifting straight up at the hinges. The door will then lift off the hinge pins. Reinstall the door new door by aligning it with the hinge pins and allow it to seat straight down. A simple repair.
If you have any questions about this repair, or require addtional assistance, please let me know. I hope this helps you.
Aug 11, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
2004 Mercury Monterey left frnt window sector gear R&R proceedure
are you a techie? You need a heavy duty riveter to do this repair. May have to rent or borrow from auto store.
here's the procedure
Front Door Trim Panel s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (251 KB) NOTE: LH side is shown. RH side is similar.
  1. Remove the parts in the order indicated in the following illustration and table.
  2. Item Part Number Description 1 23942/23943 Mirror access panel 2 1722897 Cup assembly 3 W56904-S424 Window regulator control switch panel screws 4 14A665 Window regulator control switch panel
    Removal Note 5 W701930-S424 Front door trim panel screw 6 W701930-S424 Front door trim panel screw 7 N602703-S61 Front door trim panel screw 8 1723943 Front door trim panel 9 W705590-S300 Nut insert(s)
  1. To install, reverse the removal procedure.
Item 4: Window Regulator Control Switch Panel Removal Note
  1. If equipped, disconnect the electrical connector(s).
Door Window Glass — Front s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (328 KB)
Special Tool(s) s4w~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A)
  1. Remove the front door trim panel. For additional information, refer to Section 501-01 .
  1. Position the watershield aside.
    To remove individual parts, only carry out the listed steps: Part Steps Front door window glass 1, 3 Front door window regulator 1-5 Front door glass run 1, 3, 6-8
Item Part Number Description 1 W706495-5100 Rivet (2 required)
Removal Note
Installation Note 2 N8621986 Nut (3 required) 3 21410 Front door window glass 4 W706495-5100 Rivet (4 required)
Removal Note
Installation Note 5 23200 Front door window regulator
Removal Note 6 N800507-S Bolt (2 required) 7 21596 Front door glass run 8 — Front door glass run (Part of 21596)
Item 1: Rivet Removal Note
  1. Connect the window control switch.
  1. Connect the battery.
  1. Position the door window glass halfway down to gain access to the door window glass rivets.
    • Remove the rivets.
9391398.gif Item 4: Rivet Removal Removal Note
  1. Remove the rivets.
Item 5: Front Door Window Regulator Removal Note
  1. Disconnect the electrical connector.
  1. s4w~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Prior to power window motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind. Failure to place the regulator arms in a fixed position can cause the spring to suddenly release resulting in personal injury.
    NOTE: The counterbalance spring assists the window in the upward direction.
    Remove the bolts and the window regulator motor.
Item 4: Rivet Installation Note
  1. Using the special tool, install the rivets.
Feb 21, 2009 | 2004 Ford Freestar
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Washing Machines Logo
79 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
