Question about Sony SDM-HS95P/B 19" LCD Monitor
My screen is too bright -- it's like an overexposed picture. When I try to adjust it nothing happens. Does this mean that my screen is going bad? I bought it in Dec. of 2005. Thanx
  • 29 Answers
Can be that your screen is dying. Also try adjusting settings through operating system.
Posted on Jul 18, 2009
Hi my sony vio vgn txn 15p video is faint
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
Dec 09, 2010 | Sony VAIO VGN-TXN15P/B Notebook
My Sony CRT TV keeps going on and off. The sound stays on but the screen goes on and off
Do you mean the picture is blinking on & off every few seconds ?
Sony will do this if the picture is going bad. You might try to adjust the master brightness or screen control.
remove the back cover and look for a black square box, it will have a red wire attached to it that goes to the picture tube, this is the high voltage transformer. On the back are 2 knobs, one for focus and the other for screen. Try turning up the screen control. You can use a screwdriver if you want, but there should be no danger of shock.
used to manage a tv repair shop
Mar 09, 2010 | Sony Televison & Video
Pink screen
Not a motherboard issue. If the screen looks pink it means the backlight tube inside the screen ain't reaching full brightness (the tube has gone bad). If it flickers? Well... remember them good old florescent tubes and what happened when they go bad? Same thing.
You have a bad tube in your screen and ... hence, a defective screen.
Apr 14, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Glaring nothing but bright can't see the picture
Try to adjust LCD Brightness.
Press Menu.
Go to LCD Brightness.
Dec 09, 2008 | Samsung Digimax D53 Digital Camera
The picture is not very bright
Good Day;
If this is a rear projection you may need to clean the lenses and mirror and try adjusting the contrast. If it is a direct view your picture tube maybe going soft (bad). If it's a Phillips/ Magnavox change CRT coolant.
Good Luck, big IRISH.
Sep 25, 2008 | Televison & Video
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Overexposed picture
My guess is the the EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display. Let me know if that is not the problem and I'll assist you further.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Mar 18, 2008 | Nikon Coolpix 5700 Digital Camera
My picture is too light (overexposed).
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sony SDM-HS95P/B 19" LCD Monitor Logo
472 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
