Question about Troy Heavy Machinery
Cs4210 troy bilt making sawdust instead of chips
When I put stick through the chipper I get very small chippings like a saw dust instead of chips like I am expecting? Is this normal?
  • 749 Answers
Probably need to sharpen blades.
Posted on Nov 20, 2017
2 Suggested Answers
SOURCE: Describe your Troy Troy-Bilt® Briggs and
I Have a MTB chipper shredder, model 24A-464B062 (sometime between 2000 and 2002), which appears to be a Lowes model. In my case, I left the shredded blade on and backed off the main bolt holding on the impeller so that about 1/4 of an inch of threads were showing. I then attached my harbor freight automotive pulley puller (Pittsburgh - item#66868), with its shaft pushing on the head of the main bolt and its arms hooked onto the shredder blade. I then torqued the puller hard until the shredder blade was bending pretty good. The impeller did not come off. I then used a cold chisel and a hammer to pound around the center cylinder of the impeller (there are two small spots where this can be reached). Still the impeller did not come off. I then used my plumbing torch (with MAPP gas), to heat up the center of the impeller, for about 5 minutes. Still the impeller did not come off. So I returned to the cold chisel and hammer, and after a few hits, the impeller popped loose. I removed the automotive pulley puller (be careful, it is hot), and then the main bolt, and the impeller came right off. After inspection, I noticed that there is no key and that the impeller is attached by a press fit taper. So it looks like what I did is most likely what everybody else would have to do for my model.
Posted on Jul 21, 2012
Troy bilt chipper/vac model 47287 manual
I bought a bad photocopy of the Operator manual from a seller on eBay, and put it online:
[URL="http://asavage.dyndns.org/Troy-Bilt/"]http://asavage.dyndns.org/Troy-Bilt/[/URL]
It\'s not great quality, but it\'s better than nothing.
I\'ve got some parts manual pages there, too. Also of dubious quality, but you can make out the part numbers.
Mar 24, 2012 | Troy-Bilt Chipper Shredder
I was chipping a limb and it locked up. I did not receive an owners manual and I just bought it today.
The 3 models of Troy Bilt chippers are on this page:
http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54996_54992_54992_-1
Click on the picture of your model and you are given the option of downloading the manual. You need the serial number of your machine to do this.
Hope this helps!
Mar 10, 2011 | Troy-Bilt Chipper Shredder
I have a troy built 250cc chipper shredder.. it
hi yes you can. when you take the back off you can reach the cuttingwheel and clean everything. after that its ready to use again.
Jan 30, 2010 | Troy-Bilt Chipper Shredder
Describe your Troy Troy-Bilt® Briggs and Stratton Chipper Problem how to take impeller assemply off troy-bilt chipper model cs4210
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Jun 26, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Chipper makes "sawdust" instead of "mulch"
Reduce the speed control lever to slow down the engine.
Jun 15, 2009 | Troy-Bilt® Briggs and Stratton Chipper
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy bilt pole saw will not lubricate any more
I assume you are talking about the oiler for the chain and if so it sounds as if the oiler is either blocked with chips or it is broke. You can go to ereplacementparts.com and put the model and model number in and it will show a drawing of the saw and you can then fix the problem.
Apr 11, 2009 | Troy -Bilt String Trimmer/Blower...
Chipper Features
look for in chipping units is the ease with which you can change the size of the discharge screens that control chip size. This allows you to make chips for various landscaping needs.
Aug 27, 2008 | Troy Bilt 24b - 060f766 5hp Chipper...
Chippers and Shredders safety tips
Make sure that the machine has come to a complete stop before removing access panels. When performing maintenance on the machine, shut off the engine, remove the key (if electric start) or temporarily disable the machine. Always feed material butt-end first. Feed shorter material into the machine by laying it on top of longer material. Do not feed material that you've raked up or scraped off the ground. You should simply place this material on top of the material that you've already chipped, as it may contain dirt and rocks that may damage the chipper. Chippers with dull knives and anvils do not feed well. This becomes a problem with any machine but especially on manual-feed units. If your operator then tries to force the material into the feed shoot, he or she creates a greater danger of slipping and getting too close to the chipper knives. Do not operate the chipper alone. Always be prepared for a fire or injury by having a fire extinguisher attached to the machine and a first-aid kit handy. It is the operator's responsibility to make sure that flying chips and debris will not harm bystanders.
Aug 27, 2008 | Troy-Bilt® Briggs and Stratton Chipper
Heavy Machinery Logo
450 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Ronny Bennett Sr.
Ronny Bennett Sr.
Wade Mobley
Wade Mobley
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
