Cars & Trucks Logo
A
Anonymous Posted on Aug 20, 2016
I AM ASKING FOR APPLICATION FORM SO THAT I CAN APPLY
PLEASE I BEG YOU WITH 2HANDS
L Pfaff
Level 3:
Top Expert:
  • Subaru Master 11,573 Answers
  • Posted on Aug 20, 2016
L Pfaff
Subaru Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3584008
Points
181713
Anon, no application required at this site, this is fixya web site.
Check the attached links,fixya info. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
About Us FixYa
Contact Customer Support Fixya
Fixya community of real people easy fixes useful advice
2answers
How to rid the bad smale
not enough information to get an answer
post again with a lot more details
CROUCAMP I NEED YOUR HELP I CANT FIND THE NAME OF MY SCHOOL ON YOUR SYSTEM.I AM APPLYING ONLINE AT TUT.
I'm not sure asking for help with your school application on a car and truck repair forum is a sign that education will do you must good.
5 speed intermittently stalls when power is not applied, will restart immediately.
If you a mechanic friend, ask to check the fuel pressure. It will tell you what is wrong.
We have applied for passport on 31-03-10 and police enquiry is done, but we haven't got our passport ,please do the help. I hope will oblige...
My friend, first off I have no idea what country you are calling from, (and please don't say here)secondly, this is a DIY help site. FixYa.com has NO PULL with the federal/national governments of the world. I am presuming you are eligible top apply for a passport in your country.
Yet, I want to help you. First go to the office where you applied for your passport and inquire as to the status of your application. If they cant help you, ask to "go up stairs" (who do they send applications to). If possible, go there in person if not, write a letter outlining your situation and ask when you can expect to receive your document. Continue this process until, if necessary, you are speaking with the Secretary of State of the Minister that runs the agency. If everything fails, apply again. If politically possible in your country, tell the press what is going on if you have to start all over again.
I hope this response helps you get your passport. Happy International Traveling.
1helpful
Whining noise from tranny when in neutral and clutch is out Thinking it could be the throw out bearing any ideas goeas away as soon as clutch is depressed
THATS THE ANSWER.....glad to be of help, please give me 4*beg ,beg,(wish all the questions where as easy......)
5helpful
What is esp on a mercedes 2007 s550
Could it be, your vehicle has Psychic intuition? Just kidding... :-)
Well, actually...it's not far from it !!!
ESP was co-developed between Daimler-Benz & Bosch, and was later adopted by Mercedes (across their range) from 1999.
As you know, most vehicles now have ABS braking...and some now have a form of Traction control.
Well, ESP exceeds the safety boundaries:
It's an intuitive system, connected to your vehicle's ABS, steering, dampers and Drive-train management.
ESP has saved countless lives since its implementation by reducing the risk of skidding on cornering and by maintaining the vehicle’s directional stability – even in critical conditions.
How exactly does it work?
1) This is achieved by selectively braking individual wheels, thus counteracting the tendency to skid in critical handling situations and allowing the driver to maintain control of the vehicle.
2) Oversteer is corrected by applying brake to the front outer wheel, understeer by applying brake to the rear inner wheel. Engine power can also be limited in some applications
3) The system can measure steering angles, lateral forces, and can compensate the damper ride height (optional).
Hope this helps....
** If this has helped you, please rate this solution **
3helpful
2answers
2001 ford expedition, rear brake burning smell after short driving distance and slight intermittent drag (like the brake was slightly applied on rear)
i see alot of bad calipers on these in the rear! so when you get the wheels off and take a look at the pads one side should have alot more wear than the other and that will be the trouble side. when you have the caliper off and the pads off. try depressing the caliper piston and if it don't move open the bleed with presure still applied to the piston and if the piston goes in after you open the bleeder then you have a bad rubber brake hose and if it don't than your caliper is bad. also if the piston goes in from the begging then you may have a defective pad and it wore faster witch may cause the piston to get jammed because it's at it's full excursion.
if you have any more question please ask. good luck
Lifters ticking can itighten them up
If you are asking if you can tighten them,then I would say you are probably not the right person for the job. Which begs the question how do you know it your lifters?
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
