Hand wheel free so is needle but cannot turn hand wheel to reverse it although it has sewn for a little while with me giving the wheel a little spin by hand now I cannot move outer ring to adjust locked tight what can I do please
Do NOT turn the handwheel the reverse direction.
If your machine is mechanical, most likely it hasn't been cleaned and oiled for a long time. Old sewing machine dries out and turns to glue which then prevents parts from moving like they should.
This web site may be helpful:
How to Oil Vintage Sewing Machine
Tri-Flow Synthetic Lube is very good because it has little teflon beads. It also does not dry out like sewing machine oil will. Then applying heated air from a handheld hairdryer will help loosen it.
Do NOT oil plastic/nylon, cams, or belts.
