Question about Microsoft Xbox 360 Console
Hi there my 360 is having some problems,when i put a game in it keeps on telling me to insert the disk into an xbox 360, or if the auto run option is off,then it will just say play dvd or open tray? after ejecting and inserting the disk lots and lots and loooots of times it will work,and then play perfectly for as long as needed? any suggestions please?
  • 26 Answers
I had the same problem on an older 360 I once had. I think that it is a problem with the Benq VAD6038 drive. The only known way to fix it is either replacing your 360 or replacing the drive. You can find new drives here. This drive works very well and reads disks almost instantly. I hope this helps you! Good luck!
Posted on Jul 18, 2009
  • 27 Answers
After taking the entire drive apart i found that the laser / moter assembly was offset. this ment that the disk was tilted 1degree towards the laser and intern hittng the laser assembly that so many peopl think is "laser burn" which actualy is the disk physically hitting the laser. how u fix this is as easy as adjusting two screws were the moter and the laser/ tray assembly meat. now thses arnt nomal phillips, flat head or torx scews. i found that stickin a drill bit in the screw head annd turnin it with some pliers did the trick. this fixes the open tray error for good unless the disk is causing it. IF anyone gets open tray ocasionally this should stop it for good. also try cleaning inside of drive make sure connection to drive is good. try turning the system on then emmidiatly opening and closing the tray a couple time.
Our game appears to have a scratch on it and won'at work
I had the exact same problem with my copy of Call of Duty : black ops, it however it wouldn't load certain maps. There are two basic solutions to this problem.
Many Tech / Game stores now offer a service referred to as resurfacing disks, basically as the name suggests it makes the surface of your game disk just like new again and is relatively cheaper than buying a new copy of the game (less than ten dollars).
Option two, which can be free (yay!) providing that you have a friend who has the same game, borrow the game off him and copy it to your hard drive, so that when you go to play the game ( you still need to insert the disk ) but your xbox reads all the game data from the hard drive on the xbox and not from your damaged disk.
  1. Load the disk into your Xbox 360 console and go to your Xbox 360 console
  2. Scroll down to My Xbox
  3. Scroll across to Game Library and hit the A button
  4. This should put you on the Recent Games window and your game should be highlighted, so you should just need to hit the A button. Otherwise, scroll to the Recent Games window and choose the game.
  5. On the game screen, choose Install to Hard Drive. This process should take a few minutes, but once it is complete, you'll be able to enjoy improved performance."
source examiner dot com
Jul 05, 2011 | Microsoft Xbox 360 Elite Console
360 problem
can you please tell us the label of the disc..
& we may know if this problem happen on all the games you played..?
thank you
May 05, 2008 | Microsoft Xbox 360 Console
Keeps saying open tray
Hi there stepanies
What to do when your Xbox Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Microsoft if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Xbox to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $130 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a Xbox Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
360 fix box
Feel Free to leave me a comment if you need further assistance.
Mar 03, 2011 | Microsoft Xbox 360 Console
Our xbox 360 elite keeps telling us to open tray drawer after inserting a disk. We tried 3 diff disks get same thing. Worked fine last pm
This is one of two problems, both involving your laser.
1: the laser is dirty, get a laser lens cleaner and run it through your xbox a few times and see if that helps. You can also get a can of compressed air and carefully spray it into the open tray slot.
2: Your laser has died, at which point your only option is to call Microsoft and ask them for a repair order. Sorry :(
Aug 13, 2010 | Microsoft Xbox 360 Elite Console
When i put a game into my xbox 360 it keeps telling me to open tray and wont load the game
One problem... The Disc Is Unreadable... clean it with a soft cloth, then insert it, if still same problem... take it back from where you bought it, and tell them the problem, they should replace the Game.
Oct 14, 2009 | Microsoft Xbox 360 Console
My xbox doesnt know its an xbox!
Tthe problem is with the dvd drive in your 360. If your console is still under warranty, Microsoft will repair it for free.
If you console is not under warranty, you can login on www.xbox.com using the email account associated with your gamertag and open a support case to have your console fixed. Using this method, the repair cost will be $99.00
Or, you can call 1 800 4my xbox and speak with a customer support tech and have them open the support case for you. Using this method, the repair cost will $120.00
Jul 18, 2009 | Microsoft Xbox 360 Console
My Xbox 360 intermittently scratches the game disk
1. you move, shake or touch xbox while running or disk is iin. solution: STOP!!!
2. The disk reader is to close to the disk. Solution: Open up xbox,. find disk reader, take picture. Show to people at game-stop, they'll tell u what to do.
3. Xbox is broken or faulty Solution: Get your money back and buy a new one or don't and keep buying games when the old 1 gets scratched
Jun 17, 2009 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
it might be the disk drive lens just inst reading. if you still have warrenty with microsoft call and tell them whats wrong. if not then it will be cheaper if you buy a new disk drive for your xbox 360 and have a game repair shop replace it or just take it to the game repair shop and they can tell you whats wrong for sure. but call microsoft first you have 3 year warrenty with microsoft depending around what time you purchesed your system.
May 31, 2009 | Microsoft Xbox 360 Console
Keeps telling me to open the tray whenever I put a game into it..not reading any disk
you re going to need a new disk drive i had the same problem and called 18004myxox and they said its a bad disk drive and would cost 100.00 to fix so i went and bought a new 360 insteadf
Apr 17, 2009 | Microsoft Xbox 360 Arcade
Says "insert xbox 360 disk only"
common problem, the disks arent clean, clean them with rubbing alcohol, nail poolish, eye glass cleaner. if they are new disks then u were ripped off, go back to place of purchase and tell em.
Jan 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
253 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
