Question about HP SureStore DAT24x6 DAT Tape Drive
Autoloader SCSI changer is not loading at system boot-startup
OS is Windows Server 2003 with Veritas BackUp Exec. I was successfully running backups on DLT Drive. Then I installed HP SureStore DAT24x6 external and I was able to function with both the dat drive and the library changer. Then while I was running some tests with configurations I suddenly lost the functionality of the scsi changer. I have checked everything and I about to uninstall everything relative to the drive and the software and start over. It appears that I may have inadvertantly deleted a driver or something and can't seem to resolve the issue.
The one item I can't find info on is the FB setting. When I recycle the drive, the self test shows the SCSI ID and the FB setting. I don't kknow what the FB setting is? However, the robotics of the changer functions independant of the software, so I am sure the libriary hardware is okay. Can anybody help with this?
3 Suggested Answers
SOURCE: Pc Freezes when attempting to access HP SSL-1016 Ultrium 460 Tape
Had same issue:
try manualy clean the drive. Check that the drive has no problems reading and writing.
computer freezes because state of 1 of the tapes is lost. the sofware can't deal with that
Posted on May 27, 2010
  • 19 Answers
SOURCE: forgot service password for HP Surestore Tape Autoloader 1/9 DLT
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Posted on Aug 12, 2010
After a full back-up was made, the tape stays in the drive
Click Start, then Run, type in services.msc and hit enter
Look for the Symantec (Veritas) backup Exec Tape engine service and stop it by right clicking it and hitting stop.
Eject the tape.
Restart the service.
Dec 17, 2009 | Veritas Backup Exec 10 for Windows Servers...
Certance DAT 72 tape drive stopped communicating with PC
We have had the same problems with HP drives and Veritas. In our case it was not the drive per se. While I am assuming that based on the date of your post that you have moved to another solution, however, I will provide for you what we did.
First shut all down, disconnect the tape drive from the scsi cable, then restart. Go into computer management and turn all your backup exec services from auto to manual. Now go to devices and do a rescan. Once this is done and you see no tape drive whatsoever in the devices shut down the server. Reconnect the scsi cable to the drive and restart.
Go back into computer management, back to devices and rescan for hardware changes. Do you see it? If so, good! Sometimes a re-seating of connectors will do that. On the other hand, it could also be a tape driver from Veritas that just doesn't work (my case), take the original driver cd that came with the unit and start that loading up. Can you see it now? Can you use windows backup to access the tape drive? Now go into services and start the services individually. Go into backup exec and see if you can read your tape. Go back to services and reset all services back to auto. If you ever have to reinstall/upgrade backup exec, think twice about using their drivers.
Nov 12, 2009 | Certance Internal DAT 72 (cd72lwh-s) DAT...
I have to admit this is a tough one. You seem to have tried most things i would try 1st.
I would suggest trying to download an eval coy of another backup program such as backup exec 12.5 from the symantec website and trying that.
This enables you to eliminate the backup software from your enquiries and if you also enable BUEX to use its own drivers (rather than the standard windows drivers) then that is another thing eliminated.
http://www.trilan-it.com/ are pretty good near the Berkshire area if you need a field call to help sort the issue but i would try BUEX 1st as that will help diagnose the problem even if you dont wish to continue with their software
Apr 16, 2009 | HP StorageWorks 18 Ultrium 460 Autoloader...
"error starting the service Backup Exec & media service"
This is most likely caused by a change in the user acount password that you created the profile with. Under network select Logon account Managment. in here you will see the accounts that you used to login to the Domain. (AD) Consider setting up separate accounts (backup, etc) for these services & scheduled jobs, rather than using the admin or personal accounts. This way you can still change the admin account password on a regular basis & maintain security, but not have to go the hassle of updating all of these at each change. You may also opt to set these specific accounts so that the passwords do not expire automatically so that you do not have to deal with that scenario.
Jan 21, 2009 | Veritas Backup Exec 10 for Windows Servers...
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Veritas 9.01 problem
I want to restore a store onto a resovery storage group. Software are Veritas backup Exec 9 and MS Exchange server 2003
Jan 07, 2008 | Veritas Backup Executive V9.1...
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
HP LTO Drive Firmware Revs For Veritas 9.1
The problem you described is not a driver problem. So long as you are using the Veritas drivers you should be good to go.
SCSI time-outs and disconnects are hardware problems.
Sometimes they can be resolved by changing the throughput settings on the SCSI controller connected to the drive. Controllers usually default to very high speeds because they are used for hard drives. Lowering the speeds to support the slower throughput of tape drives can sometimes help.
During the POST there should be a key combination you can press to access the setup for the controller and modify the throughput settings.
Aside from that you have to replace the SCSI controller or tape drive until you figure out which one is causing the problem. Maybe the SCSI card is not seated properly.
I hope this helps.
Nov 18, 2007 | Veritas Backup Executive V9.1...
HP SureStore DAT24x6 DAT Tape Drive Logo
484 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
