SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
SOURCE: No power to my WF 860P front loader washing machine
You have a bad control board,it is the first thing to replace.Whats probably causing it to fail is the off balance tub sensors.
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
SOURCE: E59 Error on Frigidaire front loader - won't spin
I finally solved this same problem on mine error code E59 and the main symptom of the drum never spinning even right at the beginning of the load cycle. I did Test 12 based on the following link: (MAKE SURE THE POWER CORD IS UNPLUGGED TO THE MACHINE)http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf. I found that the motor was fine which meant the problem was with the speed control board. On my speed control board there are 3 locations that connectors plug into it. Make sure these are all firmly connected. One of the three is a very weak press fit connection clamping over the edge of the circuit board. This had wiggled loose on my machine from all the dancing across the concrete floor in the basement this machine does. I pressed this connection in firmly, put everything back together and it started working like new!
Good luck.
Jon
