Question about GoVideo DVR4250 DVD Player/VCR
We can not get picture on VHS tape in middle of recording. The unit flashes a-tr. If we hit the menu button we can hear the program recorded. How do we get our program back
  • 909 Answers
A-TR is auto tracking, possibly due to older video cassettes or a faulty/dirty drum.
Run a wet head cleaner through the player and check the condition of the tapes being used. If the tapes are old they leave deposits on the playing/recording heads and you will persistantly have this problem.
If the problem persists, then I suspect the heads may be faulty, or may just need an adjustment.
Posted on Jul 18, 2009
Unit will record by peressing the record button. But when programmed to record, the unit kicks on per the program, tape runs but does not record anything
Vintage VHS recorders can get quite messy. Probaly you need to take it to service. Presume it's time to convert your family tapes to DVD.
Sep 25, 2015 | Mitsubishi HS-U445 VHS VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Blank VHS tapes work; Movie VHS tapes don't
Hello statman_4
I have an important question; Are you watching a VHS tape you recorded of another VHS movie? In other words did You rent Ben Hur and record it and then tried to watch the recording? If you did that's your problem. VCRs in the late 1990's (1997-1999) began to employ MacroVision circuitry in all VCRs, and DTR. MacroVision Circuitry makes the VCR record tapes with MacroVision in such a way that the horizontal and vertical sync pulses are not at the proper amplitude, and the AGC (Automatic Gain Control) is tricked into over compensating thus creating the scrambled picture. There is a way around this. You need to buy a video stabilizer SIMA makes such devices and some other companies do to. You feed the signal from your VCR into the unit and it corrects the video image by readjusting the video signal.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Mar 25, 2009 | RCA Televison & Video
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton dianewotton@yahoo.com
Oct 31, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd-vr357
I do this all the time. Press Menu on your remote control. From there go to Copy then select VCR-->DVD. If you're recording from the beginning of a tape just press the Enter button. If you're recording from another place on the tape hit Play or FF to advance you to the spot you want to start recording. Stop the tape where you want to record from and hit Enter. FF to the place on the tape where you want your recording to stop. Stop the tape where you want the recording to end and hit Enter. Hit the Down Arrow on the remote control to highlight Copy All and hit Enter. Your machine will rewind to the start point and begin recording and it will stop when you get to the indicated end point. Note: If you have more than one episode/show on a VHS tape and you want separate titles for each, you have to go through this process for each title. If you have more than one start and end point for each copy command you'll just get different chapters not different titles. I hope that made sense!!! Hope this helps you out.
pjrsop
Apr 24, 2008 | Samsung DVD-VR357
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
GoVideo DVR4250 DVD Player/VCR Logo
70 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
