I can not get this mic to pick up a thing! I have tried it on 4 different computers and none of the computers will recognize it at all! I plug it into headphone jack (not the USB version) & computer recognizes something is plugged in, but it won't pick up anything and I can never see it listed in "Devices" in Control Panel. Ready to give it a rotten review and throw it out the window! HELP!
SOURCE: pls help
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
SOURCE: Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power - http://en.wikipedia.org/wiki/Phantom_power
MXL User Guide - http://www.mxlmics.com/support/guides.html
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined - http://en.wikipedia.org/wiki/XLR_connector
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Ray
SOURCE: I have purchased a MXL 990 mic with all necessary
It might just be a sound setting on your computer that is holding you up.
Go to START
SETTINGS
CONTROL PANEL
SOUNDS AND AUDIO DEVICES
Then VOICE tab and see if your mic is selected as the VOICE RECORDING - DEFAULT DEVICE.
Just one more thing you can try, hope it's at least a little helpful.
Good luck.
SOURCE: I can't any sound from my MXL 990 condenser microphone. Please Help.
The phantom power is 48 VDC measured between pin1 and the pin2, 3.;is the phantom power on and are you using mic inputs not line, the mic cable is a xlr to xlr cable the attached is about phantom power. Always by from established sound centers, they have help by phone, I like sweetwater as they stand behind evry u item they and the don't carry bargain price material. I lije CBI cables as they are american made with quality american cable as swiss connectors.
https://cdn.shopify.com/s/files/1/0247/3799/files/phantom_power_primer.pdf
Testimonial: "Hello :) Yes, the phantom power is on. I can't tell if my microphone is broken or if my interface not having enough to power it. The thing is I got my mic and interface from eBay and I can't return it. I'm about to give up."
