Question about Minolta DiALTA Di183 Copier
C03ff - Minolta DiALTA Di183 Copier
  • 145 Answers
CAUSE: Incorrect setting. This can occur after a memory clear is performed.
SOLUTION: To correct the C-03FF code, set the machine to the correct speed by performing the following:
1. Enter the service mode.
2. Select 2 for the adjust mode.
3. Go to setting AD11.
4. Set AD11 to "1" for 18 cpm.
5. Exit the service mode.
to access the service mode .enter UTILITY KEY STOP 0 0 STOP 0 1 .GOOD LUCK
Posted on Jul 22, 2009
DIALTA DI 183. What does code CO3FF indicate?
Minolta di183 C03FF
minolta di183 C03FF Go to Adjust Mode 11, change the setting from 0 to 1.
Sep 08, 2015 | Minolta Office Equipment & Supplies
Me problem is code c03ff
Hello by mistake you have changed the copier model ..
hi...this error code appears after you clear the data in service mode...so you have to enter sevice mode
Utility+stop+0+0+stop+0+1....enter to ADJUST &specify the speed model from the table find 21-18-16
select the model you have
Feb 27, 2014 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is code c03ff for konica minolts bizhub 215
Model Setting - go to service mode press ( utility stop 00 stop 01 and go to adjust select model press off and on
Jan 24, 2013 | Konica Minolta Office Equipment & Supplies
Error c03ff bizhub 211 konica minolta no se resetea no guarda los cambios
model setting error :)
never change this setting.
if it changed,the Technical Rep.call (C03FF) will appear.
,default setting depend on the marketing area setting.
ex: 20ppm,18ppm,16ppm....
Jul 22, 2011 | Konica Minolta Office Equipment & Supplies
Minolta di183 C03FF
Nov 01, 2010 | Minolta DiALTA Di183 Copier
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Error code M1 appears and how to clear it . M2 is ok easy to clear.
How to clear an M1 code.
Solution:
To clear an M1 code, go to Counter/Maintenance/Maintenance Set and press the Clear key.
hope that help
Oct 21, 2008 | Office Equipment & Supplies
Minolta DiALTA Di183 Copier Logo
485 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
