Question about Akai DC6371 Digital Camera
SD card use
How do I switch my camera's inbuilt memory to an SD card? I have a DC-7370 Akai camera.
Buy a SD card and slide it into the provided slot by the batteries.
Posted on Dec 25, 2007
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
What kind of memory cards fit into a Akai Digital Camera DC7370
It uses SD cards. Make sure you get an SD card and not a higher-capacity SDHC card.
Jan 02, 2013 | Akai Dc7370 Digital Camera
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
There is no option for inbuilt memory on my camera
On most cameras, once you insert an SD card, they automatically use the card over the internal memory.
Nov 22, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
I have an Akai DC6371 digital camera and the card I have in it is a Kodak 128mb SD card. However, the camera will only let me save 4 pics to the SD card. I tried putting a different card in it that's...
Hi I can tell that sometime you have to format within computer using external memory card reader, not from camera. It is not recommend switching around one sd card to another camera. It cause card error. If you want to use it, then you have to save pictures somewhere in other storage or computer, and format the one you want to use in computer using external memory card reader. And then one more time format in camera (you have to insert memory card into camera) These method very helpful on like your problem. If not working, then you have either camera defective or memory defective. Thanks and best regard!
May 25, 2011 | Akai DC6371 Digital Camera
I have panasonic lumix DMC ZX1. when trying to take pictures it says pictures will be stored in inbuilt memory inspite sd card being inserted in right place and empty.
Welcome to FixYa.
Before using the memory card, it should be fromatted. Possible reason is memory card is not yet formatted for camera use.
*Note: Use the camera itself when formatiing the camera. Using PC's or another camera in formatting the memory card may cause a "CARD ERROR" message.
If the switch on the card is set to "LOCK"; operations such as formatting, recording and deleting cannot be performed.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 12, 2011 | Panasonic DMC-ZS1 Digital Camera
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
BenQ C850 Switch from internal memory to sd card?
Try other SD card. 99.99% sure that the card is not good. Borrow your card to someone to check your card with his camera,or Format the card from C850 Menu.
Jan 30, 2009 | BenQ DC E600 Digital Camera
Dc-t50 does not have menu to cancel protect on memory card
Download the firmware above... Copy it to a freshly formated by the camera SD card..  hold the up arrow for all 3 100%'s  turn the camera on it takes 2 min
Jan 24, 2009 | Gateway DC-T50 Digital Camera
Digital camera SD card
Your camera uses a SD flash memory card. You have a xD flash memory card. Basically, you have the wrong size card. Hope this helps!
Sep 11, 2007 | VuPoint DC-C517-VP Digital Camera
Akai DC6371 Digital Camera Logo
66 people viewed this question
Top Akai Cameras Experts
Tony Parsons
Tony Parsons
Are you an Akai Camera Expert? Answer questions, earn points and help others
