Question about Dometic Rooftop RV Air Conditioner
Where do you put freon into the unit at? - Dometic Rooftop RV Air Conditioner
  • Dometic Master
  • 6,674 Answers
You don't, they are a closed system, but if you can find an AC guy who is qualified, the can cut line & add valve, but can be expensive & no guarantee. Most find it's cheaper & better to replace upper unit if lack of freon is actual problem. What is unit doing that makes you think that's the cure?
Posted on Jul 19, 2009
HOW TO CHARGE OR PUT FREON
there is none have to put line tap valve on low side.
Sep 19, 2015 | Heating & Cooling
How do I replace the freon in my portable A/C unit?
you can't unless you put a saddle valve on it to hook up a hose for the gauges to put the Freon in it. If it needs Freon you have a leak somewhere. When you put the Freon in it will leak out this is why you need to find the leak.
Jul 15, 2014 | Amcor PLM-14000E Portable Air Conditioner
600 series Penquin rooftop unit
could be possibly low on freon and they are self contained units you can put a saddle valve on it and try to put freon in it. If its r22 its the high dollar freon.......have an experienced hvac guy come out.
Jul 08, 2013 | Dometic Rooftop RV Air Conditioner
Much freon c unit
There should be a sticker under the hood with the specs. If it does not have rear ac it should hold 3 or 4 cans if empty. You would use a gauge on the high side to check.
If you put too much in the high side pressure switch should cut power to the compressor clutch, but you could still damage the compressor.
Jul 04, 2013 | Ford Freestar Cars & Trucks
Put the wrong freon in a/c unit. what do i do now ? let it all out, and regas the unit or will it hurt it to leave it alone and let it run..
Reclaim and recharge. I hope you did not mix incompatible oils.
What freon did you put in verses what it should have? How much of the foreign freon is in the system (comparatively speaking)?
:o!
Jun 04, 2011 | Heating & Cooling
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
I need a diagram on how to put freon in a 2006 ford focus
The answer is simple. DO NOT GO ANY FURTHER.
You must be a federally or state licensed a/c person to add freon to any a/c unit. Even the qualified people can not put fluid in unless they can sign off the the unit does not leak. SORRY
Jun 19, 2010 | 1998 Ford Explorer
Who to added R22 freon to my a/c condenser unit and what hose on my gages need to be connected to hight pressure and lowe pressure
the red hose connects to smaller line...usually 3/8's....the blue connects to larger that has black insulation. The yellow to tank of freon. The unit must be running to put in blue hose. If unit nit running put in red hose. Must be done by someone with EPA 68 license
May 10, 2010 | Whirlwind FH-778 Air Conditioner
Window unit not cooling how to put in freon
You have to put a piercing valve on the sucction side because this units don't come with service port, but if you going to add freon ,it is better to fix the leak before and after that replace the drier and vacum the system.
Aug 17, 2009 | Frigidaire FAC124 wall/Window Air...
Dometic Rooftop RV Air Conditioner Logo
292 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
