Question about Mitsubishi WS-55809 55" Rear Projection Television
We moved the ws-55909 television and now all we get is the green flashing light. reset does not make any difference. what to do? Craig
  • 668 Answers
If this unit is 7-9 years old it probably has a DM that has failed. Unfortunately they are NLA. Give Mitsubishi a call to comfirm this at 1800-553-7278 (Parts Dept.). If they will not help you try, 1800-332-2119 (Customer Service).
Hope this helps,
Skyassoc
Posted on Jul 18, 2009
Mi mitsubishi 55859 has flashing green light that won't stop flashing and tv won't turn on
Bad digital/power module. Difficult repair. Have an authorized shop pull module and ship to Mitsubishi for rebuild. Many many caps are bad inside, and probably bad digital board. Factory service is recommended.
Jan 18, 2011 | Mitsubishi WS-55909 55" Rear Projection...
Continuous flashing green light, tryed reset button and cut power to tv, no change
The V19 V21 DM repair kit from www.tvrepairworld.com should repair that issue. The kit also contains the instructions
Nov 26, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green light on front of ws55909 projection tv. have reset it by both unplugging and pushing reset button. light continues to flash. has for 2 days. can't operate tv
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Jan 15, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS55909 blinking green light
how long was it blinking. after a complete loss of power the green light will blink on power up as it is resetting itself. It says in the manual that it should take about a minute. Over the last two days I've have to reset it several time both by unplugging it and using the manual reset button and it has taken about five minutes for the blinking green light to clear.
Dec 09, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi ws 55909
Have you tried pressing in the menu and input/device buttons both in together on the front of the set and hold them both in together for 5 seconds to see if the set will blink a two digit error code? Try that and then let me know if it blinked a code. Please reply to this same post when replying. Thanks
Aug 04, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
