Question about Refrigerators
I want to rivet a bracket to secure my refrigerator to my travel trailer wall. Where are the coils{ frigidaire Compact model}
    Champion:
  • 363 Answers
In order to be sure not to hit coils would be to use very good adhesive to secure bracket to frig and then screw wall side to secure frig.
Posted on Jul 22, 2009
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
Steps to replace thermostat on uline 2015 wc
I have a Model 2015WCS wine cooler. The thermostat control and sensor is part number 2767-1. You can find it from a number of suppliers. I called U-Line to get these instructions. They worked! I cannot stress how important it is to work carefully and slowly so you do not kink or crimp the new sensor or damage any of the refrigeration lines.
UNPLUG THE UNIT! Remove the knob and plastic front panel, and remove the back panel. Do this is a place with lots of room. Remove all of the shelves. Slightly loosen the two screws in the bottom center of the evaporator plate, inside and at the back of the storage unit. These screws secure the coiled sensing portion of the temperature sensor. Remove the screws and standoffs at the bottom of the Evaporator Plate and gently slide out the sensor. Working between the back of the unit and the back of the inside compartment, feed the coiled portion out through the hole.
Next come the HARD part. The control is mounted with two screws onto a housing within the unit. However, its removal is blocked by the mounting bracket for the button switch for the light. This button switch bracket is either riveted or spot welded onto the base of the unit. The U-Line guy told me to drill out the rivets to make room for removing the control. It's tough metal, but very possible! You will need some screws or a good pop rivet tool to re-mount the bracket when you are done. I ended up making fairly large holes and used 1/4 x 20 flat head screws.
Lay the unit on its side so you can work on the bottom side. You may wish to remove the door before doing this, or be sure the hinge in on the floor so the door will lay open. Locate where the rivets or spot welds are on the bottom outside, and drill them out to release the bracket. Take care not to drill the button switch.
After the bracket is out of the way, remove the two screws holding the Control, and feed the sensor through the back of the unit while pulling on the control. Note the path it takes for reinstalling the new one.
Now you are ready for the new part. CAREFULLY extend the sensor to its full length by gently uncoiling it. Feed it through the ho;le on the side of the housing that holds the control and then to the back of the unit. DO NOT MOUNT THE CONTROL YET. Feed the coiled end through the hole in the back of the unit. Reach inside and direct the sensor coil back into its bracket and tighten the screws. Replace the Evaporator Plate mounting screws and standoffs.
Now you are ready to mount the control in place. Using at least two screws and lock washers, secure the button switch bracket back in its original position.
Stand the unit back up and replace the back. Plug it in to verify that it is working. Replace the plastic front panel, knob, and shelves. Enjoy some wine!
Aug 21, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
U-line 2015 thermostat
You can order the part from apdepot.com. Changing it out it very simple. just pull the machine out where you can get to the front and the back easily. Once you have that done open the machine and take the two screws that are in the back wall at the bottom low center area. This will release the thermostat line inside the machine. Now just lay down in front and take the thermostat out and pull your line to you and your done.
May 30, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
I need to replace my ignition coil that sits directly behind the carburater (sp)and in front of the distributer. Would you please give me step by step info on how to do this? (I am less than shade...
Hello Friend:
#1) Ok first Disconnect your neg. Battery Cable
#2) Now Tag the wires going to the Coil and at where they were on the Coil and the Coil wire to Distributor.,Just so you don't cross them.
#3) Now Theres mounting bolts uncoil bracket ,Probally 1/2" or 9/16th Wrench.After you have Removed the Coil & Bracket ,If this is the Factory Coil it will have RIVETS holding the Coil to the Bracket.
#4) You'll need to Drill out the Rivets that are holding in the Bad coil, When you by a New Coil some Brands have 2-Screws inside the New Coil box,To secure the New Coil in the Bracket.If NOT then you'll have to by a Couple Screws.
#5) now just Reverse the Removal instructions and your in Business. DO make sure the wires you Tagged or Marked go back at the same place on the NEW Coil.
Thanks for using FixYa Please let me Know how my Answer has helped you solve your Problem by Voting for the Quality of my Solution. Thanks From: d_hubbs
Sep 19, 2010 | 1990 Chevrolet K2500
How to remove a 1989 pickup chevrolet ignition coil ,6 cil.,chayane
GM Full-Size Trucks 1988-1998 Repair Information
Ignition Coil - REMOVAL & INSTALLATION
(sSee Figures 1, 2 and 3)
Fig. 1: Ignition coil mounting-4.3L engines
  1. Tag and unplug the wiring connectors from the coil and the coil wire.
  2. Unfasten the retainers securing the coil bracket and coil to the manifold.
  3. Remove the coil and bracket and drill out the two rivets securing the coil to the bracket.
  4. Remove the coil from the bracket.
To install:
The replacement coil kit may come with the two screws to attach the coil to the bracket. If not, you must supply your own screws.
Fig. 2: Ignition coil mounting-5.0 and 5.7L engines
Fig. 3: Ignition coil mounting-7.4L engines
  1. Fasten the coil to the bracket using two screws.
  2. Fasten the coil and bracket to the manifold. Tighten the retainers until they are snug.
  3. Engage the coil wire and the wiring connectors to the coil.
Hope this help to solve it (remember comment and rated this).
Apr 21, 2010 | 1989 Chevrolet C2500
Frigidaire 7G53402944 Spot weld on door hingle bracket failed
Try a Pop-Riveter, drill small hole insert rivet and squeeze handle.
Feb 26, 2010 | Microwave Ovens
DOMETIC RM 2214 Refrigerator in Travel Trailer will not refrigerate (get cold). Worked perfectly until we recently moved it to a new location. Yes, I've levelled the unit.
Check first if the distance of the fridge to the wall is enough or has similar air circulation as with its previous location. Inspect the coil at the back of the freezer for dirt or ice build up. See if cleaning the unit including the back of the freezer will help.
Aug 22, 2009 | Refrigerators
Refrig defrost coil
by removing the back wall in the freezer. remove lower baskets and shelves. should see 4 screws securing cover.
Aug 21, 2009 | Frigidaire FRS26R4A Side by Side...
Bad miss
0900c1528008ee09.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition coil mounting-4.3L engines
To install:
0900c1528008ee0a.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Ignition coil mounting-5.0 and 5.7L engines
0900c1528008ee0b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Ignition coil mounting-7.4L engines
  4. Hope this helps
    Lefty64
Dec 23, 2008 | 1988 Chevrolet C1500
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
